Laptop cooling
Results 1 to 7 of 7
Thread: Laptop cooling
    Mako Shark Cyber's Avatar
    Ft Lauderdale FL
    Laptop cooling
    I have an odd problem,with the laptop I have.
    Is a Toshiba c655 s5132,old school but I like it very much.
    Two wks ago I replaced the cpu,and in order to do so,you must remove the board.
    While I had it out,I decided to clean the fan.When I took it out I noticed that,where the fan goes the fan opening was sealed
    AMD FX-8350 @ 4GHZ
    MSI 990FXA-GD65 BIOS V 19.9
    EVGA GTX 760 SC
    Acer 24" G-7 G247HL @ 1920 x 1080
    MUSHKIN Redline Ridgeback DDR3 rated @ 2133mhz # 996997
    Samsung MZ7TD256HAFV SATA 3 SSD 256GB
    ST1000DX001D SATA 3 64MB 1000GB Hybrid
    KenTec 1000w PSU 12v rails rated @ 36 Amps
    Windows 10 Pro x64
    Dec 2014
    What laptop culler did you choose?
    Ft Lauderdale FL
    Quote Originally Posted by bestellen View Post
    I am using the OEM that came with it.What I am saying is,the bottom cover where the fan outline is there but the slits are all closed.
    The vent is there but,is totally closed.The fan draws air from slits right below,the exhaust opening.
    AMD FX-8350 @ 4GHZ
    EVGA GTX 760 SC
    Windows 10 Pro x64
    Houston, we have lift off!
    So did you end up trying to open up those vents? The vents aren't "activable"?
    MSI R6850 PE/OC (860/1100)
    Ft Lauderdale FL
    Ok here you can see what I'm talking about
    Attached Images Attached Images
    AMD FX-8350 @ 4GHZ
    EVGA GTX 760 SC
    Windows 10 Pro x64
    Wow... what sort of material is blocking those vents? Is it easily removable?
    Ft Lauderdale FL
    No no way to take apart it would detonate
    AMD FX-8350 @ 4GHZ
    EVGA GTX 760 SC
    Windows 10 Pro x64
