SSD problem
Thread: SSD problem
    Mako Shark Cyber's Avatar
    Ft Lauderdale FL
    SSD problem
    In have a 256gb SSD and when I bought it, it said it was wiped.I have tried to get comp to see it and it does but that is it.
    I have tried booting from Win 7 dvd ,XP,Vista and I get nowhere.
    AMD FX-8350 @ 4GHZ
    MSI 990FXA-GD65 BIOS V 19.9
    EVGA GTX 760 SC
    Acer 24" G-7 G247HL @ 1920 x 1080
    MUSHKIN Redline Ridgeback DDR3 rated @ 2133mhz # 996997
    Samsung MZ7TD256HAFV SATA 3 SSD 256GB
    ST1000DX001D SATA 3 64MB 1000GB Hybrid
    KenTec 1000w PSU 12v rails rated @ 36 Amps
    Windows 10 Pro x64
    Quote Originally Posted by Cyber View Post
    Most of the reputable SSD manufacturers have something like an SSD "Toolkit" that should be able to see the drive. Samsung Magician, Intel SSD Toolbox, etc.
    What does the one from your manfucturer say about the drive? What drive make/model do you actually have?
    Ft Lauderdale FL
    The drive is a Samsung 256gb. I finally got it to accept OS,is working fine now.
    Thanks for the reply
    AMD FX-8350 @ 4GHZ
    EVGA GTX 760 SC
    Windows 10 Pro x64
    I'm using a 850 pro 256GB from the last 2 weeks. But now it is not showing in my pc and can't recognize it in the bios. I think it was broken, now try to buy another one...
