Ie 11 browse issue
Results 1 to 2 of 2
Thread: Ie 11 browse issue
    Feb 2002
    Ie 11 browse issue
    I'm noticing when I use IE 11 in some sites, it crashes. Everything ultimately freezes & I need to reboot. Is IE on its way out or is there a fix I need to make for compatiblity?
    It appears that I use Chrome more often in order to visit some sites now and I don't have any issues.
    Sep 2016
    which os u using? window 8, and u update it to 8.1 ? win 8.1 have this issue, and u can fix it to do following.
    Go to: options/advanced then turn off accelerated graphic , choose to use software instead
