VPN remote user having 2d monitor problem
Thread: VPN remote user having 2d monitor problem
    Feb 2018
    I work from home using VPN. I connect to my company via a router with a monitor connected to HDMI (only one HDMI port available). I have been using an older monitor as my 2d one successfully since last year. It is connected with a VGA to DP cable. The other night it suddenly went blank, no power, no anything. I tested it with another outlet and got power but it seemed each time I attached the VGA/DP cable, it went dead. I called my lame IT department and they were no help. I purchased a new VGA/HDMI cable thinking that was the problem but it still does not work nor does it work on another older 17" NEC monitor I had. I have ensured the display settings are correct (extend to 2d monitor) and nothing had changed up to the moment it all went dead. My IT department said they have not done any hardware or firmware updates to my router.
    Can anyone help me figure out the problem before I go an invest some big money in a new monitor? I'm lost. Thanks in advance.
    Houston, we have lift off!
    Welcome!
    How old is the monitor? And you don't have to spend a lot on new monitors... 22" LCD monitor can be found for sale around $100 or so.
    MSI R6850 PE/OC (860/1100)
    16 GB G.Skill Ares DDR3-1866|Corsair AX850
    Zotac 1060 Mini 6GB|Dragonfly USB DAC
    Logitech WingMan RumblePad USB|Logitech G5
    Heatware & eBay | the Gamer Planet | XFire
    Feb 2018
    Quote Originally Posted by proxops-pete View Post
    Welcome!
    The monitor is pretty old, about 2001, but it was odd that I got nothing on the screen with my 20" as well as my old 17" one. One monitor failing I can understand but both? that is weird. I've been looking at new monitors, I just hate to spend money if the monitor is not the problem...
    I understand but 2001 is very old... I'm surprised that they still work!
    having said that, if you have a friend's monitor you can borrow, I'd try that to see if it's the cable or your computer first...
