I just finished building my system, and i need some help. I got a XP 1900+, EPOX 8KHA+, 512 MB Crucial DDR (2x256), and Radeon 8500, among other things. My questions are: what do i set the clock and ratio/multiplier to to get to 1600 Mhz? (im not OCing yet). What should i set the AGP Aperture to- 64 or 128MB? Also, I think my IBM 60Gb 60GXP is running at ATA33, not ATA100.. how do i change this? Right now my PC is running at 100Mhz x 15, and temp is about 32 deg C hehe. Thanks
AMD Athlon XP 1900+ | Soltek 75DRV4 | 512 MB Crucial DDR 2100 | 60GB IBM 60GXP | | LiteOn 16x DVD |LiteOn 24x CDRW | ATI Radeon 8500 | SB Audigy | Antec 1030B, Enermax 330W | Tt Volcano 7, ASII | Hitachi 19" CM721F | 8517 3DMarks | Logitech Z560 | Windows XP Pro
http://gamershq.madonion.com/compare2k1.shtml?2481355
set it to the 266 mhz bus...since your board and processor supports the 266 mhz bus (or 133 as they probably refer it to in the biosand set the multiplayer to 12...12*133 = 1600 mhz...that'll give you a nice boost in performance...definately download the latest drivers for the radeon 8500...they improve performance by a lot...
Athlon 1.2 ghz w/266 mhz bus
256 megs of PC-133 ram crucial
ECS K7S5A motherboard
ATI Radeon 8500 (oem...250/250)
win 2k
and a whole lot of lovin..
Save ana...!!
Lian Li PC-K7B | Intel i5 750 | 4GB A-Data 1600 | Gigabyte GA-P55-UD3R | XFX Radeon 5850 | 2-640GB WD Caviar Blue | X-fi Xtrememusic | Klipsch Promedia 5.1 Ultra | Dell U2311H | Antec Basiq Plus 550W | NEC 3550A | Win7 Ultimate x64
Another thing that is really nice to do...you probably don't wanna do it now though but:
Format your fastest HD (if there the same speed doesn't really matter but i have a 5400 and 7200) And make a partition it so you have 5 gigs and then whatever else is left and have the 5 gig partition be the boot partition. Every time you still something put it in the D: drive or whatever as long as it's not the C:. This way it's easy to reformat if you have problems and you can keep important things...mp3's game saves movies etc.
Something else that's useful but doesn't really help your computer is create a folder in the non C: drive and call it program installs. make sub folders or however you want to do that and whenever you download a new program or driver just put it in there, saves a ton of time when you have to format and reinstall windows.
Visit my cool website for pics and info on my computer:
www.geocities.com/atc9001
Feel free to IM me if you have any questions/comments
1ghz duron@195x7.5, 8k3a, 512x1 samsung, WCing, normal GF3.
Feel free to IM me if you have any questions/comments....
PS: Durons rock
