Does Aluminum Dissipating Heat better than Metal?
Results 1 to 10 of 10
Thread: Does Aluminum Dissipating Heat better than Metal?
    Registered User James_Emerson's Avatar
    Ubon
    Post Does Aluminum Dissipating Heat better than Metal?
    Does Aluminum computer cases can Dissipating Heat better than Metal or Steel cases?.
    I'm looking at this case right here http://www.colorcase.com/products/ca....html#FEATURES
    I wonder if it will fit my 760chipset mobo
    Don't take war into a street, Do it on the internet!
    James 'Ghostrider' Emerson
    "The Outlaws player" http://www.outlaws.cc
    [This message has been edited by James_Emerson (edited January 11, 2001).]
    Aluminium is a better conductor of heat, per se. The real issue is the design of the case regarding space for air circulation and the ease of getting to each of the components without the need to skin your knuckles or remove another component. I'll take a well designed, spacious steel case over a so so aluminum case anytime.
    Toronto, Ontario, Canada
    if its just a case, then aluminum won't have much effect on case temperatures. but if you're talking about something like a heatsink, then a more heat conductive metal would go a long long way. something like silver or copper.
    Athlon 500mhz @500mhz, Microstar 6167, Infineon 384MB PC133 CL2, Maxtor 20GB 7200rpm, Quantum 10GB 5400rpm, Pioneer 16x DVD-Slot, Matrox G400 Dualhead 32MB, Aureal Vortex2, Mitsubishi 900u
    Don't tell the mods I was spamming... sssshh
    Ubon
    hmmm......
    Phila, PA
    Aluminum IS METAL.
    Copper dissipates heat better than Aluminum, Silver and Gold are better than Copper. Just look up the physical characterestics of the metals in any Physics text book.
    There are no stupid questions, there are stupid answers.
    Hammerhead Shark tuck2040's Avatar
    Everywhere, until the end of time.
    What did you think alumininum was if not metal, jam maybe?. You shouldn't be trying to cool it by conduction through the case that is crazy, you cool it by convection. Blowing air through the case takes away the hot air and replaces it with cold. To get the heat to go through the case it would need to heat te inside of the case up first.
    Being an egg sucks....
    you only get laid once, you only get smashed once, and the only woman to sit on your face is your mum!
    Duron 750
    128mb 133mhz SDRAM
    Gigabyte 7ZM
    Geforce 2 MX
    3.2gb and 20.4gb HD
    CL 52x CD-ROM
    AMD Athlon XP 2400+
    Thermaltake Volcano 11, 120mm intake + exhaust
    1024mb CRUCIAL PC2700 Cas 2.5 DDRAM
    Soltek SL-75DRV5 (KT333)
    Ati 9800Pro 128mb (stock speeds)
    Creative SB Audigy 5.1 Player
    Maxtor D740x ATA133 60gb
    Seagate Barracuda VI 60gb
    WD Caviar SE 8mb 120gb
    WD Caviar SE 8mb 250gb
    Lite-ON 48r x 40w x 12rw
    NEC 3540A DVD+- Writer
    LG 1915s 19" LCD monitor (1280x1024)
    450W Antec True Blue PSU
    WinXP Pro
    Mandriva LE 2005
    Master of the obvious Adisharr's Avatar
    A room large enough for my head
    The CASE material will have a negligable effect on dissipation..
    - No.. I don't know Moe..
    ...WAIT FOR IT
    Hammerhead Shark bluesfusion's Avatar
    Oh damn, and all these years I thought Aluminium was a metal. You learn new things everyday.
    Anyway, an Aluminum case will dissipate heat better only if you have a big oxy-acetylene flame or pyrotechnic explosions inside your comp case. =:O
    For regular computers, no it wont make a bit of difference to cooling. Its just a fad that'll suck up money from people willing to burn it.
    Duron 700@850 (1.71v), K7TPro2A, Geforce2 MX, 128MB
    Catfish MisterTurret's Avatar
    NY State
    "I'm looking at this case right here http://www.colorcase.com/products/ca....html#FEATURES
    HAH. I got that YURI case from color case because I wrote a 5 page suggestion. It was free. Anyway I havent tried the case yet, but its REALLY light. It comes with 1 preinstalled fan. Besides you can get a slot cooler. That'll do the job. As for the case. It doesn't do any of the cooling.
    "Well you know what they say. If you see a white light at the end of the tunnel, its usually a proton torpedo" (Chell from Voyager Elite Force)
    I imagine the point of aluminium cases is that they are a lot lighter than steel ones. Although not many people move there pcs round alot. I suppose if you go to lots of LAN parties?
    Duron 750
    128mb 133mhz SDRAM
    Gigabyte 7ZM
    Geforce 2 MX
    3.2gb and 20.4gb HD
    CL 52x CD-ROM
    AMD Athlon XP 2400+
    WinXP Pro
    Mandriva LE 2005
