    Charlotte, NC, USA
    Angry T-Bird way too HOT !!!!!! HELP!!!!!!
    I have a T-Bird 750 running on an ASUS A7V MoBo with a CoolerMaster AMD approved Heatsink fan (w/ silicon grease)
    Iam current at 55C on-line and reach 60 - 65 C when playing games. This is constant if Occ at 1G (100 mhz x 10) or at 750
    I have seen that bios version 1002 will help with heating problems. I go to the ASUS download page and only see 1004.X listed for the A7V. There is another bios for MoBo A7V-M that has a bios a7vm1002.zip Is this the correct one? I also can not get the files to download form the ASUS site. Where else could I find this bios?
    Please help before it goes up in SMOKE
    Make sure there's good contact with the core and HSF. In reality, you probably need a better HSF esp when OC'ing. Good case ventilation doesn't hurt either.
    Sir Acceptable_Risk,
    1st Order sapasion's OC Knights
    Reef Shark lmpulse's Avatar
    Chicago
    I've got the same gig as you but mine runs to 55 deg max.
    I use a fop32 with artic silver.
    I think you should reapply your thermal grease and get a better hsf.and make sure you apply it right and there is good contact
    AMD Thunderbird 750@1000mhz. Copper interconnects and air cooled.
    Booyakasha!
    Seen ur TB was only 750mhz and not ready to OC, for the default 1.75v.core and temp should be around 45C+ with A7V bios 1.004x. Make sure u check ur HSF contect the cpu core properly with Thermal Grease /Artic Silver which can get in any electrical Shop nearby.
    Give me ur e-mail if u agree i will send the bios which i'm using now to u. Any where, no harm for trying. Maybe it could help in ur case also. Just my little help....
    I have to go.........for working. Be back when i'm off my duty.
    CPU with not OC :
    A7V Duron 700 /Bios 1.004c /40C idle /53C full load
    A7V T-Bird 1000 /Bios 1.004c /55C idle /68C+ full load
    CPU with OC to max speed i get
    Duron 700@1000 /Bios 1.002 /31C idle /42C full load
    T-Bird 1000@1150 /Bios 1.002 /30C idle /47C full load
    (Full load with running PRIME95 ver20.6.1 for few hour)
    [This message has been edited by The LOckE (edited December 01, 2000).]
    • Athlon XP1500(10*133) @ XP2000(12.5*133)
    • EpoX 8KHA+
    • Swiftech MC462-A
    • KingMax PC2700 256MB CL 2.0
