Results 1 to 10 of 10
    Registered User
    Mar 2001
    Thumbs up to kick @$$ or not to kick @$$ system, that is question.....
    any problems here?
    good 300 watt case
    1.33ghz t-bird
    abit kt7a
    256mb pc133 ram
    elsa gladiac geforce2 ultra 64mb
    sound blaster live x-gamer 5.1
    7200rpm 60gb hard drive
    possible klipsch....
    (yes, i know i don't have DDR, but i already have pc133 and i am willing to give up the 10fps...)
    any conflicts here? thanks
    Hammerhead Shark superjohnny's Avatar
    Sol
    looks TASTY!
    Rather than get a 1.33, i'd probably try to find a AXIA based 1ghz. Both have the potential to hit 1.5ghz.
    KT7A-Raid Duron 750 @ 850 (6*142 @ 1.65v)
    128MB SDRAM CAS2
    GeForce GTS 2 32 MB (210/400 WaHOO!) NED 6.88
    40 GB 7200 rpm ATA100
    Live XGamer 5.1
    16x DVD
    Win 98SE
    Cocodrie Shark CajnDave's Avatar
    Land of Milk and Honey
    Nice system I don't see any thing that should conflict.
    I am an enigma in my families gene pool.
    non illegitimi carborundum est
    [SBC Senior Member]
    "The only thing necessary for the triumph of evil is for good men to do nothing. "
    "He that lives upon hope will die fasting."
    Benjamin Franklin
    Registered User
    Mar 2001
    no... not overclocking....anything but that....
    (adamff7 falls asleep to 21" trinitron monitor land... poor guy...)
    Mar 2001
    Downers Grove, IL (Just outside of chicago)
    Then why post in the overclocking forums?
    I would put fun stats about my pc.. but it sucks. www.pricewatch.com
    Rules are meant to be broken...
    Rule breakers are meant to be punished!
    My Rigs
    Near montreal
    It has been said many many times:
    CPU&Overclocking forum, not Overclocking forum.
    The two are related but not required. It's ok adam, just don't pay attention to what he said.
    My system specs at the ever-so popular Mr.White's WebSite
    My site
    My company site and SUPPORT US IN THE FORUMS PLEASE!
    Share the knowledge: Subnova is your superior!
    Mar 2001
    Well he didnt have a CPU specific question or comment.
    My Rigs
    Wildwood, Florida, USA
    np, and that 1.33 IS an AXIA core, so should you ever get bitten by the o/c bug, you can have fun!
    ***1st Order O/C Knight***
    P3 700 @ 868 (1.8 vcore)
    128 Meg Kingmax PC150 Ram
    32 Meg Inno3D Geforce2 MX
    AOpen YMF744 Pro
    Twin 15" Floor Speakers hooked to a 300 watt Tube Amp
    Asus P3V4X
    40 gig Maxtor 7200 rpm 2meg HD
    ***Champion of the O/C Knights***
    I'm on a borrowed system right now... will I have to relinquish my title?
    Join the SE Seti Team!
    Registered User
    Mar 2001
    Red face
    (suddenly, adamff7 wakes up!)
    whoa! 24" inches and 80hz@2304x1440! arrg....$2000....
    and i like to keep my computers for more than a year...take it easy overclockers...
    (thump)
    (adamff7 falls into trinitron dream land....again...)
    Mako Shark mellojoe's Avatar
    Arkansas
    Hmmmm....I like the looks of the system.
    If you go with multipler harddrives, a CD-RW, and a DVD, plus some case fans and a good quality heatsink, you MIGHT want to consider a 330 or 350W power supply. If it is not too much more $$$, than you might be a little happier with it.
    However, since you said you won't be overclocking, then you might not need too many extra fans. The TBird cores do get hot, so you will need to make sure you have at least an intake and exhaust case fan (not including your powersupply fans).
    If you just go standard setup - harddrive, CD-RW, and no overclocking, than 300W should be fine. I personally have two harddrives a CD-RW, CD-ROM and have gotten bitten by the overclocking bug. I currently only have an intake, exhaust, and powersupply fans plus a wimpy heatsink fan. I am buying a poop-load of fans (5 total) and a new extreme heatsink fan, so I will be seeing the limits of my 300W powersupply.
    I'm getting a bit off track.
    The point of this entire post is this: DO NOT TURN DOWN A FREE UPGRADE TO A MORE POWERFUL POWER SUPPLY. You probably won't need to go out of the way (ie. lots of $$$) for one, but don't shy away if its only $10 more.
    MelloJoe
    OC Knight of the OC Crusades
    My Specs at Mr.White's Computer Haven
    "Of course, it's hard. If it wasn't hard, everyone would do it. Its the hard that makes it great."
    -Tom Hanks
    -A League of Their Own
    mellojoe
    --in the Lian Li A16--
    DFI LanParty DK P35 T2RS
    Intel E7200 (2.53) @ 4.0 ghz
    G.Skill 4GB DDR2-1000 5-5-5-15
    Corsair 750W
    evga 9800GTX+
    Lite-ON 20X DVD±RW DL
    --watercooling--
    D-Tek Fuzion v2
    Swiftech MCP655
    2x120mm BIX GTX
    Swiftech MicroRes
    __________
    ________
    ______
    ____
    __
