Page 1 of 2 1 2 LastLast
Results 1 to 15 of 17
    Sweden
    Post Peltiers for T-Bird
    Are there any dangers or things to think about when getting one of those?
    And what type of wattage on it and powersupply do i need for one of those w a Athlon 1000 to oc?
    And what kind of speed increase may i get?
    The cpu i have now won't boot at 1200MHz at 1.85watt with my superorb..
    Texas
    There are allot of dangers using one of those and you will need a watercooling settup to cool that pelt. The pelt you use will depend on how low of a temp you want to go. Recomend at least a 156 Watt tec. That will require at least a 12 volt supply that can handle a 11AMP load. You have to deal with condensation and a whole lot of other factors if you plan on using one, advise, get all the info you can, and it is not cheep after all is said and done. First though get rid of that orb, they are worthless. Get a fob or somethiong that can handle over 1G. You may just be happy with the results and not need a pelt. My 1G AXIA is at 1378MHz with fob-38, though I will be using a 172 watt pelt on it cause I feel the need for speed.
    Knight of the loyal order to overclock the H... out of your chips.
    http://www.nikeotronik.com/
    750 Athlon Classic O\C to 1090MHz
    Water cooled pelts
    Abit KA7-100
    256MB Micron Running at 133MHz cas 2
    Voodoo5 5500
    Kenwood 72x
    Sound Blaster Live Gamer
    Cambridge Soundworks 5.1 Digital Speaker System
    Yamaha 8\4\24 Burner
    And the list goes on
    Water cooled pelts
    Abit KA7-100
    Voodoo5 5500
    Kenwood 72x
    Mar 2001
    Israel
    If it won't even boot, cooling has nothing to do with it. That is as high as the chip will go.
    ALL YOUR BASE ARE BELONG TO US!
    Overclockum, ergo sum.
    Texas
    This is totally wrong. My classic Athlon wont boot at 1020MHz with water cooling but add the pelts, well look at my sig. The more you overclock your chip the more sensitive the chip is to heat, why do you think people are going for extreme cooling?
    Water cooled pelts
    Abit KA7-100
    Voodoo5 5500
    Kenwood 72x
    Water cooled pelts
    Abit KA7-100
    Voodoo5 5500
    Kenwood 72x
    Sweden
    Hmm... So a watercooling solution is a must? Not possible to just slap a big heatsink and fan on it?
    Maybe is should try with a better heatsink first to see if the chip is the limit...
    Texas
    Like I said before first get a better HSF, the super orb are not that good for anything over 1G. try a fob-38, picked mine up for $24.
    See how this does, then if you want more, go to water then pelts. Make sure thats what you want though, it is expensive and time consuming.
    But yes if a heatsink wont do it then supercooling will.
    Water cooled pelts
    Abit KA7-100
    Voodoo5 5500
    Kenwood 72x
    Water cooled pelts
    Abit KA7-100
    Voodoo5 5500
    Kenwood 72x
    Mar 2001
    Israel
    When the computer first boots, the CPU's temp is the same as the ambient. If heat is a limiting factor, it will only become obvious within a number of minutes or hours, when the CPU's temp climbs. Extreme cooling takes care of the extra heat produced by extreme overclocking that makes it past the boot, but creates lots of heat.
    I can't really explain your results, but I don't find it logical that different types of cooling make any difference in the first seconds after powering on, since all the components are cool.
    Mar 2001
    Listen to the ones that know that posted above.
    With a Pal6035 and a Delta fan I couldn't even post above 1520 and only could get into windows at 1507ish on a limited basis. With standard watercooling I can post and almost boot into windows @ 1610! I'm also starting to see the exponential relastionship between heat and clock frequencies, when playing with extreme overclocking it appears that that last 1C makes a difference between rock stable and crash-n-burn.
    1.2 tbird @ 1.496(136•11)
    Abit KT7A
    256MB of Crucial PC133
    Watercooling: Maze2, Cooling cube, Eheim1048
    Radeon 8500DV
    IBM 60GB ATA/100
    Seagate 20GB ATA/66
    Plexwriter 24/10/40A
    Pioneer 16X DVD slot load
    SCSI Zip
    SB Live MP3+
    Linksys 10/100
    Join SE OverClockers SETI@Home
    NOT JUST FOR OVERCLOCKERS
    Sweden
    Thanks alot for the input!
    What about the Alpha 6035? is it any good?
    Mar 2001
    With the Delta fan it kept my 1.2 @ 1.480 w/ 1.875v about 10C above ambient at idle and 21-22C above ambient at full load.
    Abit KT7A
    Radeon 8500DV
    IBM 60GB ATA/100
    Seagate 20GB ATA/66
    SCSI Zip
    SB Live MP3+
    Linksys 10/100
    Mako Shark FaTs's Avatar
    Brisbane, Australia
    [quote]Originally posted by AlphaZero:
    Right
    Your wrong
    My celeron cant boot 1200 with a retail HSF but it can boot it with a pelt. Look at your bois the cpu temp on startup is around your max load temp.
    {~SBC Member~}
    Prince FaTs Of OC
    OC Crusaders
    Celeron 600@1206
    "Who is wise ? He who learns from everyone."
    [This message has been edited by FaTs (edited April 19, 2001).]
    OC Crusaders
    Sharkyforums 3DMark Team
    My OCAU Folding Stats | My Sharkyforums Folding Stats | My Offical F@H stats | My F@H Boxen
    |I have a computer of some sort, maybe Dell?, anyways the salesman said it was the best and always would be|
    Sweden
    That's defenetly good enough for me! Gonna get me one of those bad boys! As it is now with my orb the cpu get's unstable at 1166 and the highest it will post at is 1186MHz, but after some usage i get a blue screen. and that's at 1.80v.. Increasing it won't help at all.. So i hope this is due to my crappy hsf. I just want it too get above the 1200 line...
    My temp is 53C after looping the UT demo for 20mins, so if it would get any higher than that it would probably be unstable.
    Athlon 1GHz @ 1.13GHz (1.75v fsb oc only)
    Superorb (It chipped my chip man!!)
    Asus A7V rev 1.007 (from 1004d)
    256mb Mosel vitalic cas2
    Asus GF2 GTS Deluxe 32mb
    2x46Gb IBM 75gxp
    Sb live player 5.1
    Hitachi DVD gd7500
    40x cd-rom
    300w case w 2x80mm fans
    Nokia M5122 ADSL Modem on a 768Kbps line (up&down)
    Brisbane, Australia
    You have an A7V so get a Alpha PEP66w/delta they are the second best HSF avail for Socket A
    {~SBC Member~}
    Prince FaTs Of OC
    OC Crusaders
    Celeron 600@1206
    OC Crusaders
    Sweden
    The second best? What's the best then?
    Brisbane, Australia
    Swiftech MC462
    {~SBC Member~}
    Prince FaTs Of OC
    OC Crusaders
    Celeron 600@1206
    OC Crusaders
