Results 1 to 9 of 9
    Post Need some help guys.
    I'm set on buying new mobo chip and mem. Will keep my current parts etc.. just wanna hand dow my old proc and mobo to my little sis to give her an increase etc... ANYWAY, having some problems decideding what chip to get!
    This whole Athlon XP **** has got me all confused... the 1600 is actually a 1.4 ghz right? Whats the difference between the 1600 and the Amd 1.4 T-bird 266??
    The mobo I plan on getting is the Epox 8KHA+, good choice? or whould you suggest something else?
    I think i'm set on the mobo, just need help on the cpu thanks.
    *Epox EP-8k7A
    *512megs pc2100 ddr Crucial
    *WD 30 gig and Igm 120gig @ATA100
    *GF4 ti4400
    *IntellMouse 3.0 Explorer
    *ViewSonic A90 19"
    *AMD T-Bird 1.4Ghz @266
    *Hercules Game Theater XP
    *Win 2K SP3
    Wildwood, Florida, USA
    If you get that board, make sure it is the newer KT266A board (much faster)
    Difference between Palamino 1.4 and Tbird 1.4? Data prefetch, tweaked core, things like that. Nothing major, a 1.4 Tbird is still very fast. and yes, the AthlonXP 1600 is the palamino 1.4Ghz, it's renamed using "quantispeed" technology.
    ***1st Order O/C Knight***
    They multiply!!!
    1st System - P3 700 @ 868 - 1.9 Vcore (i820)
    2nd System - Celeron 600 @ 900 - 1.9 Vcore (Apollo Pro133A)
    3rd System - Celeron 400 @ 500 (Apollo Pro133)
    4th System - K6-2 450 @ 500 - 2.3 Vcore (Sis 5595)
    5th System (just started) - Arg... I keep changing my mind - so far (KR7-RAID + 1.0 Morgan Duron)
    Join the SE Seti Team!
    ***Champion of the O/C Knights***
    I'm on a borrowed system right now... will I have to relinquish my title?
    Sleeps with the Fishes talldude's Avatar
    The North
    the 8KHA+ uses the new VIA kt266A north bridge, so it's the newer one...that's probably the best board on the market, even beats the best Nforce in about half the benchies. OK, AMD has gone pretty stupid, and put speed ratings on their chips that correspond to Intel p4 speeds. Basically, take what the chip is labeled i.e. athlon XP 1800 and -300 from it, there you go, it's really a 1.5Ghz chip. I think that's how it goes. Anyways, i wouldn't get the fastest XP (1800+ i think), it's $60 more than the 1700+ processor and there is virtually no difference in performance. Q3 you might get like 5fps more to your 100+fps which makes absolutely no difference.
    squire of an OC Crusader
    asus p3b-f
    p3 700@868, 900 is impossible but cooled by alpha p3125
    creative geforce 256 120@150 core 166@200 memory
    soundblaster live platinum
    256 mb pc-133 ram cas2 but otherwise crap
    28.5GB barracuda ATA
    creative CDRW 4x4x32
    POS box, but it works
    SE Overclockers SETI@Home Team
    So If i got the regular 1.4 T-bird, It whould be ok? I think thats what I'll do , till the athlon Xp's have a higher clock speed initally ;p thanks for the input
    *Epox EP-8k7A
    *GF4 ti4400
    *ViewSonic A90 19"
    *Win 2K SP3
    Super Shark ynd69's Avatar
    In da great blue sea...
    For the price, I'd advise you to pick the 1.4GHz Tbird. Wait for Athlon XP to reach close to 2GHz...then it might be worth upgrading.
    ~ Baron ynd69 of the OC Crusaders ~
    System Specifications
    Trance - Is it in you?
    ~ Duke ynd69 of the OC Crusaders ~
    System specs: Intel C2D E8500|MSI P45 Platinum|OCZ 2GB DDR2 1066MHz RAM|Sparkle 8800GT 512MB|HP w2207h 22" Monitor|Seagate Barracuda 7200.11 SATA 500GB|Cooler Master Hyper 212 CPU Cooler|Thermaltake Armor+ MX Series VH8000BWS Mid Tower Case|Cooler Master Real Power Pro 550W|Creative Audigy SE|Samsung SATA SH-S203B DVD Writer|Razer Deathadder Black Gaming Mouse|Razer ExactMat Mouse Surface|Logitech G15 Keyboard|Windows Vista 32-bit Home Premium|
    Pomona, CA, USA
    Thumbs up
    Direct from The Register (the first, and accurate site to break the news, *cough cough Trav2003 cough cough*) LOL:
    <A HREF="http://www.theregister.co.uk/content/3/21938.html" TARGET=_blank>XP 1500 - 1.33GHz
    XP 1600 - 1.4GHz
    XP 1700 - 1.47GHz
    XP 1800 - 1.53GHz </A>
    The four improvments in the Athlon XPs (over the Thunderbirds) are as follows (direct from AnandTech's overview/preview):
    An increase to L1 TLB Entries
    Data Prefetch
    SSE Instructions
    On-Chip Thermal Diode
    Enjoy yourself, and have fun. If you extensively use programs that have SSE optimizations, and you had dreams of using these programs will full acceleration (see a psychiatrist) Seriously though, then definitely think about picking up the Athlon XP over an older Thunderbird processor.
    Peace
    [x] AMD
    [x] Abit
    [x] 3dfx (R.I.P.)
    Hot damn these chips have SSE? Hrmmmmm Now I gotta rethink this, I do alot of video encodeing etc.... This might be benficital to my encode speeds. HMMM I just gotta calculate the prices for these bad boys.
    Hope I can get the mobo chip and mem under 350ish...
    *Epox EP-8k7A
    *GF4 ti4400
    *ViewSonic A90 19"
    *Win 2K SP3
    Smile
    The XP won't close in on 2.0. I think AMD will shelf it after ~1.73MHz. This would put it at a 13x multiplier on the EV6 bus. After this, I'm not sure exactly how AMD will go about incororating Tbred into the EV6 bus. They can either go with a 333FSB which throws a wrench into the whole backwards compatiblity concept. Otherwise, they'll have to remap all the multipliers (which wouldn't be that bad or that hard of a thing, and it would ensure backwards compatiblity). I think this depends mainly on the availability of 333MHz DDR SDRAM and how willing consumers will be to switch to a new motherboard at launch.
    Count Baron of the OC Crusaders
    All that we see and seem is but a dream within a dream
    Thonrhill, Ontario, Canada
    True...
    But I guess they could goo alll the way up to the 40x Multiplier??? LOL
    EPOX ZEALOT (Partnership with amd soldier)
    Tbird 1ghz@ 1.62 (55c Idle, might take it down to 1.5, till I get some better cooling)
    INWINq500N
    Epox 8k7a
    256 MB DDR Ram
    Kyro 2
    SB LIVE 5.1 Value 2
    17' LCD display (be here soon)
    Thermalright SK6
    20gb 7200 RPM Quantum Drive
    16X CDrw (shipped)
    40X CDROM
    ATI TV Wonder
    Agfa CL18 Cam
    Agfa Arcus 2 Scanner (5000$, got it for free)
    Logitech Webcam
    Logitech Pro Keyboard
    UPS Surge (2000$, for free)
    Check out the new HW Forums at http://hwforum.cjb.net
    You earn respect from people, not from numbers beside your name -Tio Chaharbaghi
