Page 1 of 2 1 2 LastLast
Results 1 to 15 of 26
    Aug 2001
    Post Allright guys... building first system any final suggestions?
    Abit KG7
    AthlonXP 1800
    IBM Deskstar 60GXP 20gb x2
    Pioneer 16x DVD DR-115
    Plextor 16X 16/10/40a
    Audigy Xgamer
    Geforce 2 pro
    512mb Crucial DDR
    Floppy
    Klipsch 2.1
    $1228
    Monitor -probably a 700nf
    (need some suggestions)
    $225
    Anything I should change? Anything a better value etc.? Any help would be great!
    ***My Two Cents***
    ***My Two Cents***
    Aug 2001
    Thinking of swapping out the 2.1's for pulse 424's what's your suggestions on that one? they are only $35 (!)
    ***My Two Cents***
    ***My Two Cents***
    colorado
    Originally posted by JM2252001:
    Abit KG7
    AthlonXP 1800
    Audigy Xgamer
    Geforce 2 pro
    512mb Crucial DDR
    Floppy
    Klipsch 2.1
    I'd get a Lite-on burner and a 1700 xp and spend the money saved on a GF 3. I would also get a Epox EP-8KHA+, it's cheaper than a KG-7 and arguably better. Even the $89 Shuttle AK31 based on the KT266A chipset I just setup is faster than a KG7, albeit with a less feature filled bios as Abit's. I don't just think this, it's what the benchies of the 761 and the KT266A prove.
    OC Knight
    [This message has been edited by scott (edited October 14, 2001).]
    Aug 2001
    Why the lite on? Iv'e heard nothing but blessings about plextor
    ***My Two Cents***
    ***My Two Cents***
    colorado
    Cause they are 1/2 the price of a plextor, and they burn just about anything-perfectly. Plextor is widely regarded as the best burner but lite-on is far and away the best value, price/performance wise.
    OC Knight
    Great White Shark AMD Soldier's Avatar
    USA
    Unless your running a server, raid is completely worthless. If you want it for the experince than that's the only thing it's good for.
    I'd just get a 40gb+ hd and leave it at that.
    About the mobo, it's already been said, what Scott said.
    *the Masta Overclocker*
    Games and Stuff
    My Specs
    *****AMD Soldier*****
    5 Loaves and Two Fish KJY9's Avatar
    Temporarily assigned to earth!
    Hmmm I beg to differ Soldier. If you're running Raid0 you're goint to have much faster disk access than in non-raid. Here's a bench of my rig running Raid0 which clearly shows a much faster access rate over a non-raid board
    KJY9's Rigs
    Whoever said "ignorance is bliss"??
    Reef Shark Predator2's Avatar
    The only down side when running Raid 0 is BACKUP BACKUP BACKUP $ BACKUP.
    If one disk fails ALL YOUR DATA IS LOST!
    (This wasn't aimed at you KJY9).
    And I Agree Raid 0 will BOOST your HD performance.
    Pentium Overdrive 200@200 Dhry/Whet-stone 427Mips/228 MFlops
    Asus P55-T2P4
    64MB EDO Int/Float 86/114 MB/s
    Matrox Millenium II
    Voodoo 2 3DMark2000 474
    Creativ 32 pnp
    This isn't my main unit any more(It got changed early Jan 2002).
    Mako Shark mellojoe's Avatar
    Arkansas
    I love my Plextor, but I've also heard NOTHING but great things about the Lite-On. You'll be happy either way you go.
    I'd suggest going with a RAID setup. You get TWICE the burst rate of a normal harddrive setup, and for alot of us who share movies and large soundfiles, that means a lot.
    But, you'll have to buy two identical drives, which it looks like you are. I kinda wish I'd gotten it when I had the opportunity.
    Also, for the graphics card, you can get a Radeon8500, arguably the best GPU on the market, for about $250. Get the AthlonXP 1700+ for almost $100 less and upgrade your graphics card. I don't think you'd regret that decision one bit.
    About the Klipsch...they ARE Klipsch, arguably the best sound quality for a PC setup. The Klipsh 4.1's have the best subwoofer I've ever heard (i don't know if the 2.1s have the same sub or not...I would imagine so, but I'm not sure), bar none. My suggestion is to go to a store and listen to the two setups side-by-side. THen make your decision. I mean, its WELL worth it to actually HEAR the quality of sound in the speakers before you buy.
    MelloJoe
    OC Knight of the OC Crusades
    AMD Thunderbird 750mhz @ 900mhz (6 x 150mhz :-D)
    Project ModCase: Self-Contained Watercooling
    • CoolingCube modified to fit sideways
    • Maze2 Copperblock
    • Eheim 1250/Aluminum Resevoir
    • Design and Cut CUSTOM fan grills
    • Design and Cut CUSTOM window
    • Decorative tube lighting
    My Specs at Mr.White's Computer Haven
    Quicky Overview of My Computer with Images
    mellojoe
    --in the Lian Li A16--
    DFI LanParty DK P35 T2RS
    Intel E7200 (2.53) @ 4.0 ghz
    G.Skill 4GB DDR2-1000 5-5-5-15
    Corsair 750W
    evga 9800GTX+
    Lite-ON 20X DVD±RW DL
    --watercooling--
    D-Tek Fuzion v2
    Swiftech MCP655
    2x120mm BIX GTX
    Swiftech MicroRes
    __________
    ________
    ______
    ____
    __
    I agree 1,000% Predator2!! I just had a 40GB IBM drive go down last week...thank goodness for the extra 60Gb of backup that I had. But the same thing can be said of non-raid as well...."you lose the drive and you lose everything". So by backing up, you're not doing anything extra that you shouldn't be doing anyway.
    KJY9's Rigs
    [This message has been edited by KJY9 (edited October 14, 2001).]
    Originally posted by KJY9:
    I agree 1000% Predator2!! I just had a 40GB IBM drive go down last week...thank goodness for the extra 60Gb of backup that I had. But the same thing can be said of non-raid as well...."you lose the drive and you lose everything". So by backing up, you're not doing anything extra that you shouldn't be doing anyway.
    I Feel your LOSS.(the IBM HD).
    And your right about the one HD but like one wrote somewhere on the Internet that your twice as likly to have a failure when using 2 HD instead of one, you might not but the chance is there.
    Backup is to most neglected security feature in todays security.Sad to say.
    Asus P55-T2P4
    Matrox Millenium II
    Creativ 32 pnp
    Hammerhead Shark Belial's Avatar
    I would get a faster video card and a much bigger HD.
    Get a Ti200 if you want to get a cheap geoforce3 card(or an original geoforce3 when they start going on fire sale) or go all out and get the Ti500 or Radeon 8500. your video card is going to have the greatest impact on your system with that fast of a processor and the geoforce2 pro is long in the tooth now.
    20 gig HD gets filled up pretty quickly also.
    For a monitor I'd get at least a 19" and with as flat a screen as you can afford. Monitor size has a large impact on your gameing and enjoyment of a system.
    ASUS CUV4X-C
    Win 98 SE
    PIII 1000mhz/133 FSB 148
    Sony 21" G500 monitor
    2 sticks 256K pc133 cas 2
    Radeon all-in-wonder ddr
    Maxtor 7200 ata100 60 gig
    ALS 4000 sound card
    U.S. 56k modem
    floppy & cd rom drive
    ANTEC 601 case
    [This message has been edited by Belial (edited October 14, 2001).]
    ASUS CUV4X-C
    Win 98 SE
    PIII 1000mhz/133
    Radeon 8500 64mb 275/275 built by ati
    Tuttle Beach Santa cruz soundcard
    linksys wireless router/cable modem
    floppy & Lite-on 163 DVD drive
    Liteon 24/10/40 CDR
    ANTEC 601 case
    also: shuttle SN41G2 and Epox 8K5a systems
    Tiger Shark LionHe@rt's Avatar
    Oct 2001
    Toronto, Canada
    hmm, how come i constantly hear the IBM drives go down?
    Duron 700 @ 900 (1.80V)
    Vantec 62540D
    MSI K7T PRO2A
    256 MB PC133 Cas3 Infineon
    128 MB PC133 Cas3 Micron
    Asus V6800 DDR Deluxe
    SB Live! Value
    330W Enermax PSU
    Maxtor 30G 7200RPM
    16X Pioneer DVD-ROM
    17" KDS Avitron
    AMD AthlonXP-M 2500+@2300Mhz|Thermalright SK7|1.5GB DDR400|Asus A7N8X Deluxe 1.04|Sapphire Atlantis Radeon 9600 128MB OC'ed|Chaintech AV-710|Pioneer 16X Slot DVD|NEC 2510A|Seagate 80GB|Seagate 200GB|Mitsubishi 1.44MB Floppy|Zalman 300W PSU|Compaq 1825 18.1" LCD|Logitech Cordless Navigator Duo SE|Altec Lansing MX5021
    I've had two go down in the past year..that's out of 8 drives. Not a great ratio, and their RMA dept sux. They held onto my last rma for 3 weeks before shipping out my new drive, whereas Maxtor shipped out the day after they received one of my drives. I'm still not sure that the extra performance you get out of an IBM drive is worth the poor customer service.
    KJY9's Rigs
    Great White Shark Mandorallen of Molynnr's Avatar
    Mar 2001
    South Africa
    Unfortunetly
    they do seem to have a high failure rate. Almost everyone I know with an IBM hard drive has had at least one RMA. Others like me, have had six or seven RMA'd drives. (lost count somewhere along the line.)
    Duke of the OC Crusaders
    System Specifications.
