Results 1 to 8 of 8
    Post KT266+... is SOYO the way to go?
    http://www.gotapex.com/reviews.php?rev=kt266a/p6.html
    I was looking at this site comparing a few KT266+ boards.. is the SOYO really the best out there?? or should I be looking at something else?
    "A mathematician is a blind man in a dark
    room looking for a black cat which isn't
    there." -- Charles Darwin
    there."
    Super Villain Moderator Un4given's Avatar
    For the price, what you get with the board (integrated 10/100 NIC and 6-channel audio with adapter), in addition to having some very good o/c features, it is definitely a board that should be on the consideration list. The reviews I have read also indicate the board is very stable.
    Besides, there is just the plain old coolness factor with the black PCB and the purple PCI slots; especially if you have a modded case with a window and a light kit.
    Just my $.02 though.
    Earl for the OC Crusaders
    P3 700@980 (140x7.0 1.85V--dropped from 1001 to o/c video higher)
    Abit VH6-II w/256MB PC150 (2-2-2)
    Radeon 64MB VIVO 205/205
    SBLive! Value
    13.5GB & 30GB Maxtor ATA100 (5400RPM)
    Memorex 36X CD-ROM/TDK 8x4x32 CD-RW
    Intel i7 3.2GHz @ 3.93GHz
    USA
    Talking
    Hi there!
    I built my new PC this past weekend using the SOYO Dragon+ and had only a few problems. Overall the board is very good - it has a one quirky layout issue- the CD-ROM signal wire connects between two PCI slots - which are located after the AGP slot- which boils down to a wire running over and on top of my GeForce3 card. Not a big deal, but makes me a little nervous. I am running WIndows XP and had stability issues until I flashed the BIOS with veriosn BA1 - now things run smoothly. I also had sound problems until I figured out I had plugged the wire in wrong! DOH! The sound is VERY good as well, almost as good as my SB Live. The board is very stable, is very fast and I am very happy. Also, SOYO documentation is not all that great- it is easy enough to follow the diagrams, but their english needs some work. I hope this helps! Let me know if you have any other questions!
    Here is my new PC:
    Athlon XP 1700+
    SOYO Dragon+
    512MB Crucial DDR RAM
    GeForce3 Ti500
    InWin Q500 case
    My new System:
    Athlon XP 1700+
    Soyo Dragon+
    GeForce3 Ti500
    512 MB Crucial DDR RAM
    InWin Q-500 Tower
    Sony Trinitron 19"
    _________________________
    "The trouble with too much self love, is that eventually you become jealous of the people who envy you!
    -Me-
    Sep 2001
    I been reading reviews of the soyo mo/bo with others and im not fare off buying it this xmas.
    Spring Lake MI, USA
    Thumbs up
    I have the SOYO DRAGON (not the +) and its great! I hear the DRAGON + is a lot better. I find that hard to believe because the DRAGON ran flawless and was easy to use, in other words it was perfect. How can the DRAGON + be better than perfect? I hear nothing but good things about the DRAGON + and with my experience with the DRAGON, I say go with the DRAGON +! As of late SOYO has been putting out some great MOBOs!
    THE GAMING MACHINE!!!
    1.4ghz T-BIRD w/AYHJA stepping @1.606GHZ(146FSB, CPU stepping 11.0, +0.075V) 100%Stable
    2X256 NANYA PC2100 CAS2 (512mb total)
    SOYO K7V DRAGON (built in DOLBY 5.1, RAID, and NETWORK)
    PLEXTOR 16X10X40A CDRW
    LITE ON 16X48X DVD
    SONY 1.44 FLOPPY
    2X20GB IBM 60GXP hard drives
    RADEON 8500 at(293/280(560))
    PCI 2 PORT USB card
    INTAKE 2X92mm PANAFLO FANS
    EXHAUST 2X80mm FANS & 1x120mm PANAFLO FAN
    OCZ GLADIATOR SILVER (for CPU)
    SONY 19" HMD-A400/L FLAT TRINITRON monitor
    ALL CABLES ARE ROUNDED OR HAVE ROUND TUBING ON THEM
    WINDOW IN THE SIDE!!!!
    ANTEC SX1040B w/400watt PS
    RAID 0
    WINDOWS ME on 30GB
    WINDOWS XP PRO on 10GB
    Cable modem
    Sidewinder Game Voice
    Sidewinder Freestyle Pro
    Pioneer vsx-456 Receiver
    Infinity rs-1 speakers
    2 BLACK LIGHTS in the case!!!!!!!
    LOOK AT MY SCORE FOR MO 3D MARK 2001- http://gamershq.madonion.com/compare2k1.shtml?1922368
    [This message has been edited by akhad612 (edited November 29, 2001).]
    Check out my computer at http://www.legendsystems.net/akhad.html
    Or click on the link to my home page!
    Mar 2001
    NYC
    Will boards like the Dragon Plus cause less IRQ conflicts due to their integrated components than pci sound and nic in addition to other pci devices?
    Texan Dragon Moderator Galen of Edgewood's Avatar
    Ft Irwin, CA
    akhad612, how's the sound on that board?
    Dragon of the OC Crusaders
    The race is not always to the swift, nor the battle to the strong, but that's the way to bet.
    **-- Damon Runyon
    Break the rules and you're snack food for this dragon...
    Mako Shark Paladyr's Avatar
    Mar 2001
    Cinci, OH
    Yea, that is the board I have decided on. It looks sweet and I have only heard good things about it. Also, I think you mean to say KT266A .
    My Rig
    Milhouse: "Remember when your dog ate my goldfish and you lied to me and said I never had a goldfish? Then why did I have the bowl Bart? Why did I have the bowl?"
    Core 2 Duo w Radeon 4850, Droid Phone, Mits HD1000U projector
