Results 1 to 7 of 7
    Lachenaie, Quebec, Canada
    Question video card with 1080i output?
    Are there any cards out there that support 1080i hdtv output? read output cause I don't care that a card support 18 hdtv formats in input. I want to plug my computer to my 56' hdtv and get 1080i resolution which would give me something like 1280x1024 in computer resolution.
    yogda
    Guest
    i think you can find what u want by reading the ATI Radeon's specs =)
    yogda
    Guest
    I actually don't think the Radeon supports 1080i OUTPUT. I don't think there are any cards which support this right now. There is talk about an ATI HDTV tuner daughter card or something similar coming within the next 4-6 months, and perhaps that will enable HDTV output as well.
    Smile
    no the ATI radeon doesn't do 1080i in ouput...the way they say it is confusing...in fact for the last 3 months I thought it did...waiting patiently for it to come out. And I recently emailed them to make SURE it would support it but they said it did not!
    Post_it
    Guest
    To answer more of your questions, I would HIGHLY recommend this site : www.avsforums.com Goto the Hometheater PC part and they will have an answer to most <if not all> of your questions. These are _very_ knowledgable people! They live for using there computer for the hometheater. Everything from 27" direct views to 144" front projection from a computer. Hope this helps.
    Post_it
    Guest
    Sorry. the link should be www.avsforum.com
