Results 1 to 5 of 5
    Mar 2001
    Las Vegas, NV, USA
    Question Random Lockups..............help
    I recently purchased a
    AMD 850 Tbird Socket A
    Abit KT7a
    256 mb PC133 ram
    I run Win2k Pro, which i had to reinstall due to the fact that I changed to a different chipset and Win2k did not like that at all.
    Now I get some random lockups while just in Windows and when it shuts the monitor off it won't come back if left off for a long time.
    The monitor is the only thing that gets turned off, not the HD's, and all the Power Management in the bios is turned off.
    I don't get it..........
    I'm dying over here..........hehe
    AMD Tbird @850mhz
    Abit KT7a
    256mb PC133 cas3
    ATI Radeon 32mb DDR
    Sound Blaster Live!
    Maxtor 30 gig 7200rpm
    Maxtor 10 gig 7200rpm
    Plextor 8x4x32
    Windows 2000 Pro
    Montreal, Qc, Canada
    Abit KT7a
    256 mb PC133 ram
    Right click on desktop> properties> screen saver> power management. Check there.
    If that doesn't work, I recommend a windows update to service 1. It really helped my stability as far as win2k pro goes.
    You may also need a critical update. And I recommend the i.e 5.5 update. Of course, if your not on a high speed connection, settle for Service pack 1.
    ~Share the knowledge~
    You don't have the guts to be what you wanna be, you need people like me, you need people like me so you can point your frign fingers and say that's the bad guy..So say goodnight to the bad guy, it's the last time your guna see a bad guy like this again.
    AMD Platform Screenshots: Now with 3DM2K and 3DM2001 scores
    AMD Platform System Detail's
    System & Benchmark's. *New screenies* - Now with AMD Soldiers Screenies
    MY AMD Platform System Detail's
    Mar 2001
    Las Vegas, NV, USA
    I have SP1 and 5.5 installed
    i did a backup to get alot of my stuff back but some of the apps did not come back right I'm wondering if I should just reformat again
    Processor temp = 45 to 50 C
    I thought that would be the problem too but according to AMD the max Die temp is 90 C
    AMD Tbird @850mhz
    Abit KT7a
    256mb PC133 cas3
    ATI Radeon 32mb DDR
    Sound Blaster Live!
    Plextor 8x4x32
    Windows 2000 Pro
    Mar 2001
    Las Vegas, NV, USA
    I have all the right updates on this.
    I still need some help though
    ideas?
    AMD Tbird @850mhz
    Abit KT7a
    256mb PC133 cas3
    ATI Radeon 32mb DDR
    Sound Blaster Live!
    Plextor 8x4x32
    Windows 2000 Pro
    When you say that you changed your chipsets you mean that you just replaced your motherboard and used the rest of your existing components right? It may be time to format your hard drive with extreme prejudice and do a full reinstall...but only as a last resort. Did you get the latest drivers for your chipset?
    Is it just me or is Yurimaru from Ninja Scroll the gayest guy in animation history?
    Go watch Lord of the Rings!!! It beats staring at flies swarming around a hot steaming pile of poop anyday!
