Results 1 to 13 of 13
    United States
    Post GeForce2 MX DDR Enough?
    I have a 16Mb TNT2 M64 now on my old cpu. I was wondering if upgrading it to a GeForce 2MX DDR if I would see a large difference. I play my games anywhere from 1024x768 up to 1600x1200 in 16 bit color and I might use FSAA a little. I play mostly FPS games. My system is
    P2-400@398
    TNT2 M64
    128MB 2 sticks of 64 PC-133 SDRAM
    56 US ROBOICS Modem
    2x DVD
    32xCD
    TBS Montego2 soun card.
    "Warning Windows could not detect your keyboard. Please press F1 to Retry or F2 to abort"
    P3-800eb
    128MB PC700 RAM
    Morpheus GeForce3 220/520
    20.4GB HD ATA-66 7200RPM
    i820 mobo
    18XCD 12XDVD
    SB Live! Value
    Altec Lansing speakers 340
    100MB Iomega Zip Drive
    3.5" Floppy Drive
    Windows XP Home
    Super Villain Moderator Un4given's Avatar
    P2-400@398
    TNT2 M64
    56 US ROBOICS Modem
    2x DVD
    32xCD
    Ya, you would see a big gain in performance. You have a measly 16MB of RAM and a chip that is crippled by a 64-bit memory bus.
    Now, the MX cards using SDRAM have a 128-bit buses, and the DDR boards only have a 64-bit bus, but being DDR makes it basically the same as SDRAM on a 128-bit bus.
    Intel i7 3.2GHz @ 3.93GHz
    Hammerhead Shark NEwBoY's Avatar
    Inside my Fujitsu
    MX doesnt come with ddr ram........oh so MX memory actually has the same bandwidth of 64-bit DDR?
    Inside my Fujitsu
    ugh, the M64.......
    United States
    I know the M64 sucks.At least I think it an m64. I get great frames in UT at 1024x768 16 bit color high character detail medium world detail and min frames per second at 65 no decals and dynamic lightting on. I might even have a RIVA TNT. Ever since i got the detonator 3 it says i have that is said tnt2 before i got them.
    P3-800eb
    128MB PC700 RAM
    i820 mobo
    18XCD 12XDVD
    SB Live! Value
    3.5" Floppy Drive
    Windows XP Home
    Sleeps with the Fishes
    next door
    Talking
    YOU WILL BE VERY HAPPY WITH A MX CARD. I USE CREATIVE WITH DDR. SOME SAY THE HERCULES IS BETTER...I TRIED ONE AND HAD SEVER LOCKUPS WITH OPEN GL GAMES. EITHER BRAND...ITS ALL PRETTY MUCH THE SAME GIVE OR TAKE A FEW FPS!
    I ALSO WOULD STICK WITH A BRAND YOU KOW WILL BE AROUND IN A FEW YEARS LIKE CREATIVE! (GUILLEMONT--HERCULES--OR WHOEVER THEY ARE NOW)
    Actually, the DDR MX is considerably slower than the Hercules. We're talking about 10 fps in most resolutions. That's huge. It's only the DDR MXs that have the 64 bit bus, the SDR MXs have 128. Also, the DDR chips are only clocked at like 2x143 or something at 64-bit...much slower than 183 on a 128 bit. Go for the Hercules...I love mine.
    Jman
    next door
    Talking
    I beg to differ...if I overclock my creative I get about 10-15 more fps in Q3 and can tell no difference whatsoever in a game. 10 fps is not enough of a difference to spend 149 bucks on a mx. Save 30 dollars on the creative and buy a new game with the difference!
    next door
    Lightbulb
    I hope you don't get me wrong...just because Hercules/Guillemont did not work for me does not mean it will not for you. There seem to be many happy people with Herc. mx's. I had 2 bad experiences with prophet se and a prophet2 mx. It was tough to find drivers for prophet se because guillemont and hercules were merging at the time (I guess thats why their web page was a mess. Be an informed consumer and read articles and be the judge for yourself..10 fps will make no difference in a game. If you can afford to do so I suggest buying both (herc and creative mx's) and see the difference in your machine and then take one back. Thats what I did. You will then be the authority on your machine and will know which card is better for you.
    Good luck
    United States
    I will get a creative and if it doesnot work well i can try the hercules the store has both.
    P3-800eb
    128MB PC700 RAM
    i820 mobo
    18XCD 12XDVD
    SB Live! Value
    3.5" Floppy Drive
    Windows XP Home
    Folding Team Member sapasion's Avatar
    Folding@Home
    No
    CL is 142x2x64 instead of your standard Mx of 166x128. This makes the CL about 5% slower in general.
    It's the most wonderful time of the year.
    I am
    I have a M64 too...i al buying a Hercules MX soon..
    Folding@Home
    Good Luck with that Herc. With ramsinks you should be able to reach 210/210 on a nice OC.
