Just wanted to say anyone playing Unreal and who was thinking about upgrading to a GeForce card - dont hold back. I had a Viper2 running metal drivers which gave pretty good pic quality and high FPS (60 -70)
& stability. But I needed that little bit extra edge. So I tried the GeForce Hercules Prophet 64mb PRO . I had tried the original GeForce (3 different makes) when they first came out and had nothing but lockups in games. I swore off Geforce forever, but the new drivers 6.35 version make this newer card scream while being stable. It will cruise UT at over 100 FPS while looking good.
Make sure you download the drivers (Renderer)from Epic for unreal. I run UT in either D3d or Opengl. If you run the original UT drivers the picture will be quite dark and hard to see the enemy. The new drivers from Epic force you to turn down the brightness which I never had to do before. Picture looks awesome. No lockups at all - it's been running non-stop for 24 hrs so far. I played all sorts of games with it too. Q3, NHL Hockey 2001, with np probs.
So I say go for it.
My system specs are:
Athlon 800 K7
Gigbyte 7ix
256 Ram
GeForce2 64 Prophet Pro
IBM 20g hardrive 7200
Soundblaster X-gamer
Sony G400 19in Monitor
Pentium 4 2.66 o'cd to 3.0
ASUS P4PE /lan/1394/sat
Geil PC3500 1G Ram
Western Digital 120g
Radeon 9800 Pro
Plextor 48x Burner
Lite On DVD Burner
Chieftec Case Yellow
Thermaltake Spark 7 Fan
Altec Lansing XA3051 5.1
Sony G400 19in
Windows XP Pro
3DMark Score 18514
C'mon guys! It's so simple, maybe you guys need a refresher course, It's all ballbearings nowadays...
Originally posted by Boogy Man: Just wanted to say anyone playing Unreal and who was thinking about upgrading to a GeForce card - dont hold back. I had a Viper2 running metal drivers which gave pretty good pic quality and high FPS (60 -70)
So I say go for it.
Athlon 800 K7
Gigbyte 7ix
256 Ram
If you don't mind me asking, what OS are you running?
"You know, I have one simple request, and that is to have sharks with frickin laser beams attached to their heads. Is that too much to ask?"
Cool, I just bought that same card. My current card is okay, but causes problems in UT and Deus Ex. I'm hopeing to solve the problem. I just hope it's not Win2K that's killing my games.
I had problems with my GeForce 2 and UT. I am running win2k and in DirectX the gameplay was really laggy. I changed over to OpenGL and everything was fine.
Oh yeah - I running Win98 SE with DirectX 7.0. I'm a little afraid to try DirectX 8.0 due to hearing stability problems. Any feedback would help.
Geil PC3500 1G Ram
Radeon 9800 Pro
Plextor 48x Burner
Lite On DVD Burner
Sony G400 19in
Windows XP Pro
3DMark Score 18514
Originally posted by Boogy Man: Oh yeah - I running Win98 SE with DirectX 7.0. I'm a little afraid to try DirectX 8.0 due to hearing stability problems. Any feedback would help.
Who is this guy, anyways??
"Everybody funny. Now you funny, too."
If I couldn't type drunk, I'd still be Expensive Sushi.
So, what are these special driver from Epic you are talking about?
I am running a Hercules Prophet 2 Ultra with 1.1GHz T-Bird. Have you tried utilizing the FSAA? I have been messing around with it tonight and you can play UT at 1024x768x32 at 4X FSAA! Not too shabby.
cmaMath13@juno.com
TB 1.1GHz
Asus A7V KT133
256MB PC133 SDRAM
64MB DDR Hercules Prophet Ultra
SB Live!
45GB IBM Deskstar (ATA 100)
32/12/10a Plexwriter
16/40x Pioneer DVD
US Robotics Hardware Modem
cmaMath13@juno.com
AMD Athlon XP 1800+ @ 2200+ (166MHz FSB)
CoolerMaster HSC-V62
MSI KT4 Ultra (KT400)
512MB Corsair PC2700 (Cas2)
128MB DDR VisionTek Xtasy GeForce4 Ti 4600
80GB IBM GXP120 (7200RPM)
LiteOn 40X/12X/48X CD-RW
LiteOn 16X/40X DVD
3COM modem 56k
Klipsch v.2 400
WinXP Pro
I run UT in D3D right now at 1024x768x32. With VSYNC off it hovers pretty close to 125 fps which blows me away. ONly using patch 4.36 and stock renderer. i tried the UT S3TC disk and the LOKI ogl but it was studdery. I may try this new renderer too. I too am not using DX 8 cuz of the lack of DX 8 drivers from nVidia though there are 7.17's which apparently are buggy I've read. I guess the renderer works with DX 7 obviously too.
Cam
My rig is...
AMD Athlon 1000
ASUS A7V
Maxtor 30.5 GIG ATA 100
128 PC 133
SB Live! Value
ASUS V7700 Geforce 2 GTS 32 Meg
Dell 19" Trinitron Monitor
Sure beats the old k6-2
Cam
AMD Athlon XP 2200+
ASUS A7N8x Deluxe nFORCE2
ANTEC SLK 3700 350 watt PSU
Western Digital 80 GIG ATA 100 & 200 GIG SATA
1024 Megs PC 2700 DDR in Dual Channel
ATI Radeon 9800 PRO Retail
Dual Trinitrons Display
Originally posted by Adamp44: Cool, I just bought that same card. My current card is okay, but causes problems in UT and Deus Ex. I'm hopeing to solve the problem. I just hope it's not Win2K that's killing my games.
Run run run as fast as you can, but you can't catch me 'cause I'm The Gingerbread Man!
My System:
Asus A7A266
AMD T-Bird 1.4 GHZ (266 FSB)
512 MB Kingston DDR PC-2100 RAM
Visiontek GeForce3
Creative SoundBlaster Audigy Platinum
IBM 60 GXP 60 GB HDD
IBM 120 GXP 120 GB HDD
Pioneer 16X DVD-ROM
Plextor Plexwriter 40/12/40A CD-RW
Zip 250
Samsung 700IFT 17" .20 mm monitor
Creative Soundworks DTT 2500
3Com 10/100 NIC
Windows XP Professional
Suse Linux 7.3 Professional
Hey I noticed you have the KT7-Raid. have you tried the 3D Prophet II Pro with this mobo yet? I have both and I kept getting the beeps when I tried to start it up. I read on the go.to/kt7faq website that there is a known problem with this combo that Guillemot acknowledges. They will repair it if you RMA it. I was just curious to know if you've had any success with it or have RMA'd it to Guillemot. I'm considering RMA'ing it back to the vendor and getting the Hercules Ultra instead.
My System:
Asus A7A266
Visiontek GeForce3
Pioneer 16X DVD-ROM
Zip 250
3Com 10/100 NIC
The Epic drivers are the "Renderer" drivers you install in the Unrealtournament/systems folder. These are the D3D & opengl .dll files. I want to say that when I installed the D3D renderer driver I had a decrease in FPS and overall performance, aproximately 50%, so I put the original D3D driver back.
I installed the Loki opengl drivers over the weekend. These drivers rock!!
Make sure you edit your Unrealtournament.ini file to take advantage of the S3TC textures.
I made two screenshots of the D3D & Opengl. The Opengl blows away the D3D in looks, but performance is about the same. It also took care of that stuttering I was getting in opengl before.
On the flip side - What are the best GeForce drivers out right now? I'm currently running the Hercules 6.35? I've heard the Nvidia 6.50 are good? Any comments?
The "original" Boogy Man
Geil PC3500 1G Ram
Radeon 9800 Pro
Plextor 48x Burner
Lite On DVD Burner
Sony G400 19in
Windows XP Pro
3DMark Score 18514
