Results 1 to 5 of 5
    Apr 2001
    New York, NY, USA
    Question Tyan s1590 & Radeon 64mb Vivo HELP
    Please Help.
    My Specs:
    OS: Win2k
    DirctX8a
    AMD K6-2 400MHZ
    258mb pc-133 cas2
    Tyan S1590s AT, MOBO(Running latest Bios)
    ATI Radeon 64mb Vivo (Running latest Driver)
    MX300 sound
    30Gig Maxtor diamond 40
    Promise UDMA Controller
    Pioneer 16x DVD
    HP 8200 CDRW
    Well my problem is that my card crash every time I'm running 3Dmark 2000, or Direct X Diag tests my card hangs up (Screen shutdown),or Freezes.
    Tried Every Driver from ATI (some work better then others but all crash.
    Its not the card because I had it replaced and the same thing Happens.
    Need feed back from People with the Same MOBO + VIDEO Card
    Help
    Regards,
    Eze1069
    Mar 2001
    toronto, ontario, canada
    this probably won't help much...
    but just something to look into...
    the radeon is reknown to have serious compatibilty issues not only with certain MB's but also Win2K.
    this may be causing the crash... as benchmarking software could be stressing those incompatabilities... which i'm assuming ONLY happens when you benchmark.
    just to broaden your search... and for other members to comment on (and flame)...
    end transmission
    "sometimes i like to
    look in the mirror and
    just stare at all the
    strange stains. and
    then i get sick and
    finish brushing my teeth
    and go to bed."
    strange stains. and
    then i get sick and
    and go to bed."
    SSG - FOUNDING MEMBER (SWOLLEN OR OTHERWISE)
    Apr 2001
    New York, NY, USA
    All I know is that my friend is running his card on an ABIT board no problem with any driver.
    I think the problem is between the cards drivers and my MOBO.
    But again I may be wrong.
    Regards,
    Eze1069
    Tiger Shark Abit400's Avatar
    Doylestown, PA
    I have the same mobo in my other computer, but not the same video card in it.
    It might by the chipset of the board that is causing problems. The Via MVP3 did not have the best AGP support, so that could be the problem. Where there any drivers for any other video card installed on the computer before the Radeon, because than it might be a driver problem. Win2k, like was said before, does not really work with the Radeon at all.
    I think it is the motherboard and Win2k/drivers. You said you are running the latest BIOS version, right? Install the latest Via 4in1 drivers as well, they helped in my other computer.
    PIII667/133@667, Abit BE6, 128PC100@133, TNT1 16mb, IBM 14.4 7200 HD, Netgear FA310TX, 56k modem, Aureal Vortex2 SQ2500, Sony 2x4x24 burner and other USB stuff.
    Check out this awesome website: Extreme-Genesis
    Apr 2001
    New York, NY, USA
    Yes ,I know about Win2k and Radeon, no other drivers installed, also I found the 4in1 patch to do more harm then good.
    Regards,
    Eze1069
