Page 1 of 2 1 2 LastLast
Results 1 to 15 of 23
    Calcutta, India
    Post 5.1 sound...worth it?
    Hi...have a question i'm hoping someone out there can help me with. I'm thinking about upgrading my sound set up, but i'm not sure exactly where i want to go with it. I'm thinking about the promedias vs. creative's dtt 3500 and a high end boston acoustics setup, but i can't make up my mind as to how important 5.1 sound is to a setup.
    If 5.1 is only really useful when i'm inputting from a dvd player, then i could just as easily go with the klipch. If playing music and things on a 5.1 setup is a definite improvement over 4.1, on the other hand, then i'm propbably going to be looking more at the high-end creative and B.Acoustics products...anyone out there recently upgrade from a 4.1 to a 5.1 setup?
    Can anyone give me a comparison of a 4.1 and a 5.1 system running games, music, and dvd's?
    How important is 5.1 sound capacity in a speaker setup?
    Thanks,
    Dave.
    "i have returned"
    -random dragoon.
    It's good to be back
    Thanks,
    Dave.
    Personnaly, I couldn't justify it. The four point Promedias/FPS's can be set up to simulate a center channel.
    Sir Acceptable_Risk,
    1st Order sapasion's OC Knights
    Check out www.3dsoundsurge.com for reveiws on speakers, I went with videologics 5.1 digi theater dolby surround sound speakers. They're $150 and in the reveiw they scored 95 out of 100. I have a turtle beach santa cruz which has built in 5.1 support on the card so I think it will fare better when playing video games. 5.1 is really aimed for DVD type stuff. They gave it a good reveiw for games also.
    AMD Athlon 700
    128MB RAM
    Voodoo 5 5500 AGP
    WD 45gig ATA/66
    Turtle beach Santa Cruz
    Videologic 5.1
    DVD-ROM 12x
    CD-RW 16x-10x-32x
    Win2k Pro.
    EPoX 8rda+ | XP1900+ @ Whatever | ATi Radeon 9700 Pro | Lian Li PC-65 USB W/side window | 512mb Corsair XMS3200 C2 | Turtle Beach Santa Cruz | Pioneer 16x DVD Slot | Lite-on 24x10x40x | Maxtor D740X 60GB | 56k Modem | Water Cooled | Maze 2 | Black Ice Rad | Panaflo 120mm M1A | 4xPanaflo U1A | Crystal Fontz 633 w/ Fan Control |
    "Man these Harddrives are freggin loud"
    Registered User
    California, MD
    I've got the Live MP3+ 5.1 with the Cambridge DTT2200 speakers (the ones without a decoder). I use DVD a lot on my computer, so good 5.1 is a necessity. I also listen to MP3's the whole time I am on my computer, so good sound is a must. I find the 5.1 output from the Live MP3+ 5.1 on MP3's and CD's to be exceptional. It truly adds depth to the sound. I can't speak about 5.1 output in games, as I don't play them. Why buy old technology (4.0 or 4.1) when you can get the latest technology for about the same price?Going the route I did (Live MP3+ 5.1 and DTT2200), the cost to get 5.1 is very reasonable ($200 shipped for the whole thing). No need to buy a decoder (as in the DTT2500 or DTT3500) unless you want to output Dolby Digital to a home theater system.
    I use a sound blaster Live Platinum 5.1 and dtt3500 speakers. they sound good dam good. I feel the full true 5.1 sound with the 5.1 simulation of sterio sound sorces exceptional. the bigest drawback to my rig is cost (500 bucks US retail). I would recomend SB live mp3+ 5.1 and DTT2200. you will get the most bang for your buck (230 bucks US retail). Ive red neck rigged (yes Iam red neck) an anolog 5.2 set up iam sure any one can do the same however my redneck rig up was not as powerfull or as clear sounding as my dtt2500 or the dtt2200. there are better 5.1 speaker set ups then the dtt2200 (but way more expensive) and the dtt3500 (some cost less most the same a very few more expensive)
    Mayhem,
    Iam so far gone, Iam almost there!
    Mayhem,
    Calcutta, India
    True, high-end dolby digital setups are powerful, and the sound reproduction is generally clear, but from what i've heard and read, the klipsch speakers are more powerful than most dolby digital setups. They're also high-end, they also create clear sound, and they're also rated highly for gaming, music, and movies, and as someone pointed out in the first or second post, they create a virtual center channel to mimic a 5.1 setup. Why go with a 5.1 setup when the klipsch is more powerful?
    A high-end 5.1 setup is basically a good home theatre system, and those cost significantly more than the klipsch or the creative 3500's. Is it better to go with a really high end set of 4.1's, or with a lower end range of 5.1's?
    Back when the whole 4.1 thing was catching on, it was definitely better to go with a really good set of 2.1 speakers than to go with a cheap 4.1 setup; sharkyextreme's value gaming pc has been recommending a 2.1 setup over a 4.1 setup for months because they say it's better to invest in a few really good speakers than to go in for a bunch of crappy ones.
    So now i'm thinking of the klipsch as really high-end 4.1 speakers, and the desktop theater range as low-end 5.1's...and since they're more or less in the same price category, i'm trying to decide whether or not it's worth it to move up to 5.1 sound, when that means going to less powerful speakers. The klipsch look great, sound great, and are incredibly powerful; the onyl reason they're not 5.1 speakers is because that would put them way beyond their current price range...and then they wouldnt be an option for me anyway.
    Has anyone actually had both...or experienced both? The klipsch and a good quality low-end 5.1 setup?
    Dave.
    [This message has been edited by dchakrab (edited November 25, 2000).]
    "i have returned"
    -random dragoon.
    Reef Shark hex21cc's Avatar
    Question
    is there a way to hook up a center channel with my pro media's?
    A chain is only as strong as the weakest link.
    I like the klipsch Pro Media's Ive used them (don't own them) and I would have to say there probably the best 4.1 speakers you can buy. they sound better then my 5.1 dtt3500 runing in 4.1 mode. but on the same token midilands set up is probably the best 5.1 set up they sound as good as the KMP the only disadvantage the Midilands have over my DTT3500 is the lack of imputs and support for 4.1. Unless you get a real good Home 5.1 set up (ussually cost a grand or more) its probably best to stick in 300bucks or less mode for a computer.
    Mayhem,
    Mayhem,
    Calcutta, India
    Question
    You say they sound better than the 3500's running in 4.1 mode...but what about the 4.1's running in normal 5.1? Even if i keep it to less than 300 for a setup, the klipsch is in the same price range as a lot of 5.1 setups, and it's only 4.1, so my original questoin still remains...is it better to go with an incredibly powerful 4.1 setup, or with a crappier 5.1 setup in the same price range?
    Btw, mayhem, your other post on the differences between the sblive plat and other breeds of "live" cards was REALLY helpful, even though i wasnt the one who posted the thread. Thanks!
    Dave.
    "i have returned"
    -random dragoon.
    The KPM are 4.1 speakers my DTT3500 are digital 5.1 speakers. the only way your going to get the KPM to do true 5.1 is add a speaker and thats the hard part. Ive put together two anolog redneck rigged 5.1 speaker systems and they normally don't sound as good as the dtt2200 (anolog 5.1 speakers)in 5.1 audio. the dtt3500 sounds cleaner and louder then the dtt2200 but the improvement doesn't justify the 200 bucks more your will spend on them unless you really have a need for the inputs otherwise your better served with the midi land speakers witch also cost around 300 and the have near the same power as the KPM and sound as good (actually a little cleaner).
    Mayhem,
    Mayhem,
    Calcutta, India
    Hmmm...haven't really considered midilands yet....i'll take a look on their site and see what they're like. I do remember that the kpm's LOOK a lot nicer, or seem to, than the midi's, but i have no idea what they're like as speakers.
    So you'd recommend the midi's? Thanks!
    Dave.
    "i have returned"
    -random dragoon.
    I have a live mp3 5.1 and midiland 7100's. For music the live does not use the center channel(atleast in defaut mod) cos it ruins stereo so 5.1 is worthless for music. DVD and games is where 5.1 makes a difference. I can't tell you much more as I just got this setup a couple of days ago and since i live in an appartement I can't really push it to its limits. My last speakers were fps1000's
    ohya, I have heard the ddt2500's and I can tell you that the midiland 7100's are way better as far as sound quality goes. go to www.3dsoundsurge.com, they have a full review of these speakers.
    I couldn't recomend the Midiland 7100 I was refering to the midiland 8200. If you can't get simulated 5.1 audio from your speakers there either incompatable with your soundcard or you don't have your settings right. first you need ac3 enabled your speakers need to be set to 5.1 (in both the creative mixer and in the multimedia control panel.) you need your enveroment set to "watch movie" and movie mode one. this is the same as CMSS in a few other other apps. your not getting true Dolby digital ac3 5.1 but all 5 speakers are being used in soemthing thats more close to dolby prologic surround sound. I use the live Plat 5.1 with dtt3500. keep in mind the dtt3500 are awsome speakers they can't get as load as the KPM or Midiland 8200 but they sound really good and clean and have all the inputs I require. even though they can't really goto 100% (soundcard) + 100% (speakers) volume without some distorsion effects 50% volume was enough to get thy cops called on me by my neighbors (I was watching saving private ryan on DVD as a test) Ide say there good to about 80 or 85% volume with the loudest sounds. my biggest gripe is they cost the same as the Midiland 8200 do perty much the same thing and the midilands are louder and more powerful. Ide really like to see a 5.1 solution from klispch even anolog. but for the most bang for your buck the DTT2200 and a Live mp3+ 5.1 would probably do the trick for most people and only cost around 200 bucks (sound card and speakers) compaired to the 500 bucks I spent on my stuff. one thing you must consider is how big of a room do you want to put sound in my dtt3500 or way more then enough for my apartment. However if you want to get good sound in a large room in a large house your probably better with the midiland 8200 or a consumer home theater 5.1 setup (witch is more expensive).
    Mayhem,
    Mayhem,
    The Klipsch speakers are sweet no doubt, but depending on exactly how loud/responsive/clear you want your desktop speakers to be, you can take the DTT3500s and add a new sub to them--that way you get nice bass and digital support. That's what I did with the 2500s so I could get the bass response I wanted. 5.1 is nice when you watch a nicely engineered DVD. The phantom center of a 4.1 just can't get the job done. I've been a home theater enthusiast for years and I can tell ya, if you are sitting 3-5 ft away from your monitor, you will not be using all of the ProMedias juice. No distortion, but your ears won't let the volume get high enough to where it makes a difference.
    Peace
    Dave.
