Results 1 to 10 of 10
    Winnipeg Manitoba Canada
    Post networking and cable modem
    I just gor a cable modem hookup but now I want to hook up another computer to use it. I know you have to network the two computers.I do not want to spend a lot of money with expensive routers because the second computer isn"t used on the internet to often. I heard of two ways to network the two computers. 1. With a hub and connecting the two computers to the hub 2 putting two nics in main computer and with a crossover cable connect to other computers nic. I heard that the second way you must leave the main computer on a all tinmes. If I was to use a softwaare program like wingate would it work on a hub system where the main computer will be off. Which is the best and easiest way.
    Tiger Shark Slinks's Avatar
    Jensen Beach, FL
    Smile
    if u dont use a router than u have to have one comp on at all times to get a internet connection to both comp.
    the cheepest way to go is to have a nic card in both of the comp use a crossover wire between the two comp. and get a proxy software of some kind. no need for a hub or switch in this setup unless u want to get one in case u plan on adding more computers.
    Desktop:
    Lian-Li Case A64 3500+ 90nm 4x512 MB Kingston HyperX DDR500 2X 10,000 RPM SATA WD Raptors Raid 0 2X 6800 GT's (SLI) 600W Enermax 21" G220fb Viewsonic Soundblaster Audigy 2 ZS Klipsch 5.1 ProMedia Ultras/Sennheiser 595's
    Notebook:
    Sager 8790 17" widescree P4 3.0c 512 MB ddr400 mobile 9700 pro 256 MB
    File Server:
    2X AMD 2000+ MP ATI 9200 128MB 1GB Corsair XMS pc3200 LSI Raid 5 600GB
    EQ2 Char. Mongol lvl 60 Ranger : Server Innothule : Guild Bidean Caer
    Thanks for info. Would a software program like wingate or sygate work on two computers connected by a hub?
    The cheapest way is to buy a crossover cable if you already have the software, but you need the server(CPU with internet access) on when you want to use the otehr computer. You can get 50' for $10 or 100' for $20 if you shop around. If you don't have anything yet you could get a switch, which is like a hub but a little better for about the same price and that way you could add more computers to your home network if needed(Plan for the future). With a switch you won't use as much CPU as with software. Check out www.pricewatch.com, u can get a switch for under $50 plus shipping.
    Schmitty
    EG 278
    Jensen Beach, FL
    Lightbulb
    ive never hear of wingate or sygate but ill tell u the one i used it was relativly easy to set up its call comsocks. u can d/l a tril version i think it lasts for like 90 days for free @ http://www.linkbyte.com/. it has a fire wall and all that acciting stuff.
    Desktop:
    Notebook:
    File Server:
    Atlanta, GA
    IF you're using win98 or win2k, the easiest way is with ICS Internet Connection Sharing. It works better in win2k than it does in win98, but it will work. If you have win2K on your main computer already, just add another NIC to it, and then get a cheap 4 or 5 port hub, hook the 2nd NIC up to the hub, hook the other computer up to the hub as well and enable ICS on your NIC that you have connected to your cable modem. It works the same way in win98 also IIRC. Good luck.
    AMD Athlon XP 1400/266
    Swiftech HS/Fan
    MSI VIA266 Chipset
    512 MB PC2100 DDR
    GeForce4 4600 128 MB
    Hercules Game Theatre XP
    Intel 10/100 NIC
    (2) 40 GB IBM Desktar's
    Pioneer 16x DVD Rom (slot Drive)
    Samsung CDRW (24x)
    Enermax (350w PSU)
    Lian-Li PC-60
    Houston, Texas
    Go to this website for very good info on cable modems: www.cablesense.com/old
    I heard that Sygate's a very good internet sharing program, however, it is somewhat complex in installation (tried installing it). Have tried Wingate, found it to be somewhat limiting.
    As to ICS in Windows, I think it's great as long as you don't try to host internet games....ICS will not allow you to do that!
    With all internet sharing programs, if you want your second system to access the net, you will first have to turn on your "server" (one with the connection to the cable modem) and then the second one.
    I am using Sygate 4 for internet sharing..
    i recently upgraded from sygate 3.1
    i find that 4 is very easy to setup..
    its auto config as long as you set the internal and external ip right..
    Reply: What are your settings Maybe I can find my problem by looking at yours and compare with mine. Because I cannot get ir to work even though my network between my two computers is working fine
