Ok, I'm thinking about buying a MP3 CD player and was hoping for some input. I'll probably use it in the car and at work if everything works well.
Many people recommend the Rio Volt which seems to work well for most people. I'm having trouble finding a DC car adapter that would work with it (4.5V at 5W) but I'm sure its out there.
Comments on the Rio Volt or another Mp3 CD player?
TBird 880 (oc 110 x 8) /
ABit KT7 (YH) VIA 4.29 /
256 MB PC133 RAM /
TNT2 16MB (oc 160/160) Det 7.58 /
Maxtor 5.1GB 85120A8 & 40GB 5T040H4 /
ESS 1869 & NetGear FA311 10/100 NIC /
Win2k Pro SP2
The only ones I know of (at a decent price) are the Rio Volt and something by Panasonic.
I've never actually held the panasonic one, so I don't know !@#$ about it, but I've used a Rio Volt before...
It's not too heavy compared to a normal cd player, but it's bulky as !@#$. It's at least an inch larger in diameter than a cd player, and it's about an inch thick.
Luckily, it comes with a little bag, so it really is portable, even though it won't fit in your pocket like a normal cd player would.
I've been thinking about buying one, but they're kind of expensive.
Athlon 1.4ghz, Epox 8K7A+, 512mb Crucial PC2100, Elsa Gladiac 920, Hercules Game Theatre XP, Maxtor 40gb, Creative Encore 12x, HP 9310i 10x4x32, 3com & Netgear NICs
The only good MP3/CD player made is the Pine D'music. The Rio Volt bites. Doesn't work as it's supposed to, and even worse, it's got the feeling of a light, plastic-y feeling (sorry, ripped from Maximum PC). However, it's the second CD player to have and LCD screen on it.
#1) Big Box Core 2 Quad Q9550 - Asus P5Q3 - 8GB DDR3 1333 - GeForce 550Ti - Win 7 Pro
#2) IBM Thinkpad R51 Pentium M 1.6GHz - 1GB PC2700 - 80GB - Win 7 Pro
#3) Macbook Pro 2.4GHz Core i5 - 4GB - OS X Lion
#4) Rollerskates Bont Quad Racer Carbon - Sure-Grip Avengers - Qube 8-Balls
Now Playing: Forza 4, Wipeout HD, Dead Space 2 (again!)
I have a Rio Volt, and it's a very nice CD player.
It has decent skip protection, but not great. You can't jog with it, but it didn't skip once all the way from Missouri to Georgia and back (in the car).
Originally posted by Ashpool: Doesn't work as it's supposed to, and even worse, it's got the feeling of a light, plastic-y feeling (sorry, ripped from Maximum PC).
I've heard the Rio Volt used to not work very good, but it has updated firmware now and it works very good for me.
Perhaps Maximum PC tested the Rio Volt when it had bad firmware, because what you said was completely false.
Also, I don't think it feels light or plastic-y. I like the way it looks and feels.
Well, that's what I heard from "you-know-who". Quite often, they're right. You sure that the latest firmware fixes it (I know how it works: Burn it on CD and then play it on the player. I like that )? I first wanted to get this, but after the negative feedback that I've heard from MPC, I dissolved that thought immediately.
Pine D'music, huh...never heard of that one. I'll have to look at it.
I thought one of the best and most promising features of the Rio Volt was that you could flash an update to it. This way, new features could be added/fixed increasing the value AFTER I buy the product. That doesn't happen very often in the electronics industry.
256 MB PC133 RAM /
Win2k Pro SP2
Could someone explain the necessary file hierarchy for one of these type players?
I have ~20 discs full of old phish shows I burned to clean off my expansive 6 GB drive. The file are in folders, and sometimes subfolders. Would I be able to access them?
well i got the napa mp3-cd player and works a treat comes with remote and charge and playes vcd,s rigged up to me telly and works fine and i put it on me old car kit from me cd player and works fine has a 45sec jog on it it is a litle bit bigger than a normal player but i use it in me truck when i go away save swapping the cd,s all the time
cost me 80£
AMD 1333@1460 266FSB
THEMO ENGINE V60-4210 IDLE 37C LOAD 43C
SOLTEK MOBO/133A
GE FORCE 2 PRO 64ddr 200/400MEM
256 CAS2 RAM 133
30 gig hd
TDK 24/10/40 RW
TOSHIBA DVD12/40
DTT3500 SPEAKERS
EPOXAK7,RAID,256/2100 DDR MEM
ge force3 64ddr 240/480MEM
40 gig hd
30 gig hd
30 gig hd
TDK 24/10/40 RW
TOSHIBA DVD12/40
DTT3500 SPEAKERS
my friend got a riovolt off the net and its sooooo nice
yeah its a little big, but the mp3 cd thing is good....u would switch cds a few times if u have a HUGE mp3 collection and a lot of time to listen to music
for normal cds i still like my sony g protection though
Athlon 1200/266 @1301/274
Asus A7V133
384 MB Crucial PC133
Leadtek Geforce 2 Pro 32 MB
SB Live Value
Toshiba 16x DVD
Philips 8/4/32 CDRW
40 GB IBM 60gxp
I don't know what you guys are arguing about. The TDK Mojo kicked the asses out of everyone in the mp3-cd player industry. The stuff from Pine and Dlink were among the first ones to come out, and then the Rio Volt had a good ID3 tag display, but in the end it was the Mojo that ruled. The philips expanium was a tad expensive...
All in all, forget every other brand. The king is the Mojo
Mirrors should reflect a while before throwing back an image.
Originally posted by hobbes2112: Could someone explain the necessary file hierarchy for one of these type players?
The Rio Volt will navigate nested folders just fine. You can see "where you are going" on the display.
I just updated my firmware to the new 2.01 without a problem.
You can pick them up now at Costco for pretty cheap.
P3 866, WBK-32, Win2k, Asus CUSL2-C, 512MB Crucial CAS2, GF2 GTS 32MB (Dell OEM), 3com 10/100, Promise Ultra100, Pioneer DVD-106S, Sony CRX-140E CDRW, IBM 75GXP 30GB, Maxtor 60GB, ZIP250, Antec SX830, Sony G400, fuzzy dice
P3 866, Asus CUSL2-C, 512MB Ram, 20GB and 40GB Seagate Barracuda IV drives, Plextor 24/10/40 CDRW, Lite-On DVD-163, Leadtek GF2 Pro 32MB DDR, Sony G400 19"
The RioVolt is amazing.
I've had one for about 3 months now, and have never had a problem with it. Plays anything I throw at it, even stuff that wont play in my DVD player that supports MP3 CDs.
One MAJOR reason to get the RioVolt is the firmware upgrades. If a new music format comes out or they want to add a feature, you just download an update, burn it on a CD-RW, pop it in and it updates itself.
Very cool stuff.
Asus P299 440ZX
P3 450@558 (124 fsb) w/stock HSF
384meg Micron PC133 RAM
32meg ATI Rage 128 @ 105 core/130 mem
10gig WD 5400rpm
SB Live Value
4x4x24 Mitsumi CDRW
44x OEM CD-ROM
17" .27dpi monitor
2.1 Samsung speaker w/subwoofer
@Home cable (2.2mbps/384kbps)
"One and one are one eleven"
"I was wrong, this changes everything..."
--Maynard James Keenan, Tool
MSI KT3 Ultra
AMD Athlon XP 1800 (1.53ghz) @ 2000 (1.67ghz)
Volcano 6cu 4550rpm HSF
Aron Alto case w/window
Sparkle FSP300-60BTV 300watt PS
256mb PC2100 DDR-RAM
64mb ATI Radeon 7500 DDR @ 320/400
20gb Fujitsu 7200rpm
80gb IBM 120GXP 7200rpm
SB Live Value
DLink 10/100 PCI NIC
4x4x24 Mitsumi CDRW
44x OEM CD-ROM
17" PureFlat monitor
2.1 Samsung speakers w/subwoofer
