OK, so I just got my Rio PMP300, its got a smart media card expansion slot, my question is this... some information on the player says that its limited to 32meg upgrades, others say "including but not limited to 32meg smart media cards" any one have experience with something like this? Im kinda worried about springing for a 128meg card and then finding out it doesn't work in it... someone help!!
just a friendly neighborhood OC Knight
Abit KT7a-Raid
AMD Thunderbird 1.2ghz @ 1.4ghz
OCZ Gladiator with Delta Fan
ATI Radeon 32meg DDR
768megs PC-150 Cas2
40gig IBM Deskstar 60GXP
Creative 6X DVD
Lite-On 16x10x40x CD-Rw
SB Live! Value
ATI TV-Wonder
USR 56k V.90
Netgear FA311 10/100
Samsung 955DF 19" Monitor
Win2k
AMD 2200XP @ 1.94ghz (13.5*142)
1gig Crucial 2700
Epox 8K5A3+
256meg GeForce 5600
200gig WD SE
160gig WD SE
2x 80gig WD SE in RAID0
MAG 17" LCD
IO/Magic Dual Mode 4x DVDRW
Creative 6x DVD
I would say your safest bet would be to call the company or check their website and see what they say. I use smartmedia cards all the time here at work, and they are quite nice, but they aren't cheap, so you want to make sure it will take something above 32megs before you spend the cash on them.
Current system.
Enlight case
CPU- AMD 1.33ghz 266
DFI AK76-SN MoBo
256 ddr ram
Creative 52x cdrom
HP 8/4/32 burner
Viewsonic G90F 19in. monitor
Maxtor 45gig 7200 ata 100 HD,
Geforce2 gts 64mg
SB. live oem
" I raise a sunken smile as I serve the ones that serve, what can I achieve when you steal the air I breathe!"
Current system.
Enlight case
DFI AK76-SN MoBo
256 ddr ram
Creative 52x cdrom
HP 8/4/32 burner
Geforce 4 4200 64mg
SB. live oem
For the past 2 digital cameras I had, i have been able to use a bigger SM card than the mfg said I could use. I even emailed the companies and asked them the largest size I could use, and the gave the typical response. We only guarantee it to work with X size card. My Ricoh camera said it could only use 32mb, but i put a 64 in there. I was amazed to see that the # of pictures left on the LCD display actually showed the correct #.
Expensive? Heck 64mb cards are around $27. 128Mb are a bit more at $60, but that's still dirt cheap. I remember paying that much for 4mb cards a few years back
He who joyfully marches in rank and file has already earned my contempt. He has been given a large brain by mistake, since for him the spinal cord would suffice.
-Albert Einstein
-Albert Einstein
Hell yeh i remember a year ago the 64's wer like $200 thats liek 5times what they cost now , expensive shmensive.
AMD 1800+@2294+
512 MB PC2100 @ 300
120GB+2X60GB HDD
ATI Radeon 8500
Hercules Game Theatre XP 7.1 With Logitech z-680 & X-220.
DVD +/-RW.
ATI TV WONDER
Koolance PC2 modded.
2X19" LCD
Enermax whisper 450watt
