Results 1 to 9 of 9
Thread: PHP problem
    Post PHP problem
    I'm a beginner in PHP, and I've tried to make some code by myself. I've stubled across this problem I can't seem to solve.
    When I use the line <? include("/cgi-bin/banner.cgi"); ?> I get an error msg.
    Warning: Failed opening '/cgi-bin/banner.cgi' for inclusion (include_path='./:/usr/local/lib/php') in /home/outerfx/outerfx-www/banner.php on line 1
    It seems as if the PHP thingie doesn't know how to read from root with /. How do I define this, so that it will be correct?
    To use /cgi-bin in HTML works fine, why?
    Ursus Arctos Moderatis Grizzly's Avatar
    Providence, RI USA
    Where exactly is your cgi-bin in relation to the banner.php document?
    Lemme guess...
    cgi-bin is here:
    /home/outerfx/cgi-bin
    and as it showed in your code, banner.php is here:
    So...here's how I would include "banner.cgi"
    <? include("../cgi-bin/banner.cgi"); ?>
    Should work...I *think*
    Yes, that would work if the file I put <?include("../cgi-bin/banner.cgi"); ?> in, is in /home/outerfx/outerfx_www, but I'm using header and footer files for the layout, and all the files retrieve from them, so therefore if the file is in f.ex. /home/outerfx/outerfx_www/things it won't work.
    Shouldn't there be a way to specify the include_path variable or something?
    [This message has been edited by Trophy (edited January 26, 2001).]
    Providence, RI USA
    Hmmmmm, I've flipped through my book and can't seem to find an include command that starts itself at the rootweb. I know that this is easily done in SSI, but we're lookin' at PHP here....and I'm stumped. I'm *sure* there's a way to do it in PHP, but my limited knowledge of the language prevents me from seeing it. Sorry buddy, and good luck.
    Well, well... we're at the point where we really need more programmers in here, again...
    I guess I'll have to find out a way to get around this problem, though I doubt I'll get any way with it.
    Know anywhere else I could look or ask?
    Cool
    It wasn't really a big problem.
    All I had to do was include the whole root path.
    So instead of just /cgi-bin/banner.cgi it would be /home/outerfx/outerfx-www/cgi-bin/banner.cgi
    Thanks anyways.
    Providence, RI USA
    Well....how in the world does the PHP script know weither to interpret the include as a relative link, or an absolute link? I've only used them with relative links...so naturally I assumed that that's how they worked.
    Reef Shark Pestilence's Avatar
    Hickville, USA. :(
    Well with absolute linking at least on the server side couldn't you just give the location right from the c:/ to the file?
    Kill em all and let God sort'em out.
    WoU
    Orc, 6.3k acres
    God damnit, better graphics != revolutionary gaming! Get it through your skull!
    Providence, RI USA
    Yeah that could be an idea, lol, didn't think of that!
    But what confused me is you said this worked:
    Now...if you php page was in the outerfx-www directory....than wouldn't it be looking for the file in
    /home/outerfx/outerfx-www//home/outerfx/outerfx-www/cgi-bin/banner.cgi
    Cause really....looking at that alone, the PHP interpreter has no idea if your intentions are relative or absolute.....or does it?
