I plan on modifying my case with a jigsaw .... what kind of blade should i use, the shorter or longer jagged blade?
AXIA TBird 1.333GHz @ 1.48GHz
Abit KT7A-Raid
2*256MB PC133 (Generic)
Alpha PAL3065 w/ delta
Radeon64 VIVO @ 210/210
Santa Cruz
Maxtor 40gig ATA-100 7200 RPM
DLink 538TX Network Card
Geeks Don't Dance ... We BoOoGiE!!
1.33 GHz AYHJA ThunderBird (CAK38 w/ Delta)
Asus A7A266
Antec sx830
Prophet II MX
SB Live! Value
Cambridge 4 point surround w/ sub
Kingston NIC
Creative 52x cd-rom
some random 6x dvd-rom
60gxp 40gb
256mb Crucial PC2100
you want a metal cutting jigsaw blade, this blade will have more, finer teeth than a wood cutting blade.
the higher the number of teeth the better the cut, but make sure you remove every electronic component from the case first, including the power supply because metal shaving can short out lots of electronics and the jigsaw causes some major vibrations which could destroy some of your more delicate components
all in all i've had more success with a dremel, it may take longer but it seems to work better
