    Austria
    Post Will a Alpha PAL6035 MFC and a YS-Tech 60x60x25 1,44Watt handle a XP1600?
    Will a Alpha PAL6035 MFC combined with a YS-Tech 60x60x25 1.4W 20CFM handle a XP1600?
    I do not plan to overclocking...
    what do you gurus think?
    [This message has been edited by Exode (edited December 07, 2001).]
    ASROCK 939Dual | A64 3000+ @2400MHZ 268MHZ HTT| 2x1024MB MDT CL 2.5 3 3 8 1T | MSI 6800GT @ ULTRA
    Running Man mystifmagic's Avatar
    Austin, TX
    That should cool it very well, since the 6035 is massive when compared to a stock cooler. The 6035 is a bit older cooling technology, but none the less it will cool that CPU very well at stock speeds. Good Luck
    "OH Reggie, you have hidden corners...." Duets
    3DMark2001:8755
    - My Compare
    My System Specifications & Heatware
    Join us over at The Got Hardware? Forums
    Austria
    not that I donīt trust your judgement, but are you really sure???
    We are talking about a 20 CFM fan here...
    My thought is: If a Cooler Master EP5-6I31-C (recommended by AMD to 1900+) with a 28 CFM fan will do, this setup should do just aswell? Or am I wrong..?
    thanx again for any answers
    Austin, TX
    As I said it will cool the CPU very nicely when running at stock speeds. The 6035 is a good bit larger than any stock cooler, plus it has a copper base. It's just a much better cooler, and much higher quality. The 20Cfm fan will cool it well while being very quiet.
    3DMark2001:8755
    - My Compare
