Results 1 to 6 of 6
    Apr 2001
    Fargo, ND
    Unhappy I can't get my plextor to burn a audio cd using Easy CD creator 4
    My problem is that I can’t burn an audio CD. I am using Easy CD Creator 4.03 and have a plextor 16/10/40A, I create a cd layout then when I click on the create CD it tells me "there are no supported CD-recorders available. Ensure that your CD-Recorder is powered on and that all cables are properly connected. You may also need to update Easy CD Creator to recognize your CD-Recorder." I have the latest OEM of it 4.03. I am using Smart Buy 16x CD-Rs, I know that my burner is working because I have no problem burning data to CDs using same kind of CDs. Is there something in the setup? Please HELP. Thanks in advance Frenzy.
    System Specs:
    Windows ME
    Antec SX 830 Case w/300 watt power supply
    Asus cusl2 motherboard
    P3 1ghz
    256MB Crucial CAS2
    45GB IBM Deskstar 75GXP ATA100 7200rpm
    Plextor 16/10/40A CD-RW drive
    Creative labs SoundBlaster live platinum 5.1 w/livedrive
    Still using onboard graphics until the geforce 3 comes out at lower prices.
    Aztec winmodem, will be changing to NIC and cable modem
    Tech 3 1/2 “ floppy
    Logitech iToch cordless keyboard
    Logitech cordless MouseMan Optical mouse
    19” Samsung 955DF
    Have 2 speakers now looking for a good 5.1 system
    Reef Shark Gackt2k's Avatar
    Mar 2001
    Surrey, BC, Canada
    perhaps it didnt support the 16x speed for writing music cds, try to set it to 8x, hope this helps, good luck
    AMD T-Bird 900MHZ
    256mb cas2 SDRAM
    Geforce 2 GTS 32mb pure
    MSI K7T Pro2A
    IBM 30GB ATA100 7200rpm
    Toshiba 16x DVD
    SB Live!
    Samsung 955DF 19"
    win98se / Windows 2k pro - Service Pack 2
    AMD T-Bird 900MHZ @ 990MHZ
    512mb cas2 SDRAM
    MSI K7T Pro2A
    Toshiba 16x DVD
    Aopen 12x cd-rw JustLink
    SB Live!
    Samsung 955DF 19"
    Logitech Z560
    Win ME / Windows XP Pro
    Apr 2001
    Fargo, ND
    nope thats not it, but thanks for the input. I tried changing the speeds it dosent even try to burn, as soon as I click create CD the window pops up saying "there are no supported CD-recorders available. Ensure that your CD-Recorder is powered on and that all cables are properly connected. You may also need to update Easy CD Creator to recognize your CD-Recorder." Please help, has any one with a plextor 16/10/40A had any problems with Easy CD Creator creating a audio CD? Please help this sucks not being able to burn audio CDs.
    Irvine, CA
    I would uninstall ECDC and then reinstall it again to see if that helps. Also, do you have the latest firmware for your Plextor? Another thing you might want to do is ditch ECDC for Nero Burning ROM, which can be found at www.ahead.de
    You can get a 30 day demo there and try it out. I think once you do, you won't be using ECDC again...
    P3 904 (139x6.5), WBK-32, Win2k, Asus CUSL2-C, 512MB Crucial CAS2, GF2 GTS 32MB (Dell OEM), 3com 10/100, Promise Ultra100, Pioneer DVD-106S, Lite-On 12x10x32x w/BURN-Proof, IBM 75GXP 30GB, Maxtor 60GB, ZIP250, Antec SX830, Sony G400, fuzzy dice
    P3 866, Asus CUSL2-C, 512MB Ram, 20GB and 40GB Seagate Barracuda IV drives, Plextor 24/10/40 CDRW, Lite-On DVD-163, Leadtek GF2 Pro 32MB DDR, Sony G400 19"
    I had similar trouble with EZCD5. I fixed it by using the repair option from the uninstall menu in control panel.
    athlon 900
    ga-7zx
    win98se
    ibm 30gb
    32mb creative gts 2
    256mb pc133
    sb live 1024
    yamaha 8x8x24
    pioneer 16x40
    Apr 2001
    Fargo, ND
    Thumbs up
    Thanks everyone!! That did it I uninstalled it then reinstalled it and it works like a charm. I think I am going to give nero a try thanks for the link 311_man.
