Basic Hardware help, on tight budget.
As the topic obviously says, I'm a teen on atight budget trying to build myself a computer. I generally do a lot of heavy work in 3d graphic and 3d arts and play tons of games. I recently won a contest and sold something so I finally have enough cash tog et myself my own computer.
However, my experience with actual hardware is minimal. I need advice on the following parts for compatability and just general opinions on them. I've only got around $950 for a whole system from scratch. After pricing I've decided this is the cheaper way to go.
Anyway, enough rambling here are the parts I currently have:
Case: Raidmax Model 268WBP(BLACK/SILVER) 10-bay Case Retail $27
Motherboard: Asus VIA A7V333 KT333 Chipset ATX Motherboard Retail Boxed $94
Processor: AMD Athlon XP 2200+/266 FSB Processor CPU - Retail Box $170
RAM: SimpleTech (Simple Technologies) 256MB DDR PC2100- OEM $42
Hard Drive: Maxtor 80GB 7200RPM Hard Drive 8MB $110
Floppy Drive: Generic $8
CD/DVD ROM: Still deciding Max: $75
Video Card: ATI RADEON 9500 PRO 128MB DDR DVI AGP $197
Speakers: Creative Labs Inspire 5.1 5200 - RETAIL $73
Total: -SEE BELOW-
Lacking:
Keyboard, Mouse, and Power Supply
I know the RAM is small, but I already have two sticks I can use (one 256 and the other 64... thus the three slot Motherboard).
OS I already have, and the keyboard and mouse would be a present.
I really hope to get the most bang for my buck and want some knowledgable opinions.
Thanks in advance,
>--------------------------| WebMaster | TheAggressors.com |----------------------<
>--------------------------| GR.net | AGR-S.com | Tranceweb.net |------------------<
>--------------------------| "My trade is to say what I think." -Voltaire|-----------------<
That MB don`t use PC133 ram, it uses DDR ram.
i7 920 @3GH, P6T Deluxe V2, OCZ HP 6GB(3x2)Kit(7-7-7-16), 128GB Patriot SSD, 250GB SATA(7200)Hitachi, WD 500gb, 1000W BFG PSU, SATA Pioneer DVD CD burner, XFX5870 XXX edition(900/1300), LG LED 2350V, XFI Titanium Fatal1ty champion, Logitech X-540, Lian Li PC-B70 Full Tower Case, Win7 HP.
Old School OCer
Welcome to Sharky Extreme Forums
For some more ideas, go to the homepage here and go down the left side and click on value gaming system. Do you need a monitor? More later?
Changed the RAM... can't believe I overlooked that.
I'll go ahead and check the main page. Yes, I probably will need one... unless I can bum one off someone I know.
I'm thinking no larger than 17".
Old School OCer
Re: Welcome to Sharky Extreme Forums
You could find a mobo that uses SDRAM but DDR RAM will yield much better performance, especially if you're a gamer. I'll get back to you on some alternatives.
What about your OS? Do you use Windows 98/2K/XP or Linux?
If you use Windows XP Home Edition or Professional, I would recommend you to buy an additional 256 mb DDR ram. Your system will run much smoother with 512 MB DDR ram if you do a lot of artwork and play games.
- Mathematics is the language of nature.
I have no ideas on where to begin with Monitors, but found this one:
Monitor: NEC/MITSUBISHI MultiSync FE770-BK 17" (BLACK) FLAT SCREEN MONITOR $148
As for RAM, I'm only cutting it small because I have an additional 320M at home that I can use. For a grand total of 578M.
My OS will be Win 98 (because I already own it) but if I have enough at the end, I'll go with Win XP Home Ed.
Current Total: $897
Case: ANTEC SOLUTION SERIES Model# SLK2600AMB w/ANTEC SMART POWER 300W P4/AMD POWER SUPPLY ATX12V - RETAIL $56
Motherboard: Epox Motherboard for AMD Socket A Processors, model EP-8K5A2 Retail $79
Processor:A thlon XP 2100+/266 FSB Thorougbred Processor CPU 2100+/ 1.73GHz -OEM $93
HSF: COOLERMASTER DP5-7JD1B-0L CPU FAN SOCKET A/370 CPU $17
RAM: Samsung Original DDR333 PC-2700 256MB CAS2.5 - OEM Version $55
Hard Drive: Maxtor 80GB 7200RPM Hard Drive 8MB Model # 6Y080P0 $109
Floppy: SAMSUNG 1.44MB BLACK FLOPPY DRIVE Model# SFD321B/KEB - OEM, DRIVE ONLY $8
CD-RW: Lite On 48x24x48 CDRW Model LTR-48246SBlack OEM $58
Video Card: ATI OEM RADEON 9500 64MB DDR 8X AGP BULK $141
Speakers: Logitech Z640 5.1 Speaker - RETAIL $67
Monitor: NEC/MITSUBISHI MultiSync FE770-BK 17" (BLACK) FLAT SCREEN MONITOR - RETAIL $148
OS: Microsoft Windows XP Home Edition with Service Pack 1 - OEM Full Version $93
TOTAL: $939
Athlon 64 3700+
2GB Micron DDR400
Shuttle ST20G5 SFF
ATI X800XL 256mb
Seagate 160GB
Generic 8x4x8x DVD+-RW
Dell 17" Trinitron (just bought a 2005fpw!!)
And my soon to be 1.5TB server
Wow. Very nice.
The only things... I don't need a brand new OS. -$93
-I also am debating on Video Cards. My mind has been set on a GeForce4 Ti series for a while now, but after seeing it on another machine; I was not impressed.
-The motherboard you mention only has a 4x AGP slot, would it be better to go with the one I was shown (my original post) that has an 8x AGP?
-Will 300W be enough to support either of these systems? Or should I go with a 350W or 400W?
Go with the Radeon 9500. Performance is almost as good as a Ti4600 even though the price is about the same as a Ti4200. Check out the article on it. It should be on the front page.
A quality (ie Antec) 300w should run your system without any problems.
Heatware - 50+/0/0
GIGABYTE GA-P55M-UD3 - Core i5 750 - 4Gb DDR3-1600 - Enermax 720w - Sapphire Radeon HD 5870 - 1Tb WD Black - 1Tb Samsung Spinpoint F2 - 1.5Tb Seagate 7200.11 - LG GGC-H20L HD DVD/Blu-ray - Samsung SyncMaster 205BW - Vizio 42" 1080P - Logitech Z560 - Logitech MX1000 - Windows 7 Professional
jw, what are the specs on those other two sticks of ram???
| X Dreamer II (yuck, i know) | MSI K7N2 Delta L | AMD 2800+ | ATI 9700 Pro | 512 Crucial pc3200DDR | Samsung 52X32X52X16 DVD/CD-RW Combo | Audigy 2 OEM | WD 80GB SE | Windows XP Pro | NEC 19" CRT | Microsoft Keyboard | Logi MX500 |
_________________________________________
. FREAKISH .
Audio:
Klipsch Promedia 5.1s
FB2k > EMU 0404 > ZA-Pimeta > HD 580s
Portable
H120 > KSC75's
Z-Audio Forums are up!!!
@ATacoGuy, I read the article. Very interesting. It's worth checking nito!
@CadetLee, thank you. Any idea how much this will run me?
@Freakish, I have no idea. The 64M came with the motherboard about 5 years ago, and the 256M was bought almost a year ago (not the cheapest, but not the most expensive).
---EDIT---
Changed the Video Cards. I'm convinced.
Current Total (using my specs in first post, monitor and new video card): $944
I'm pushing my limit.
i bet the ram you have is sdram, not ddr. They are not interchangable
Athlon XP 2800 Barton
Abit AN7
256meg Samsung PC-2700 With Thermaltake Ram Cooler
512meg Crucial PC-2700 With Thermaltake Ram Cooler
All In Wonder Radeon & Diamond Viper PCI
Sound Blaster Audigy
Lite Oo 16x DVD-ROM
Lite On LDW-451
WD 80gig Special Edition
Antec True550
Antec 1080AMG
Logitech Z-640's 5.1 Surround!!
Here's my current system, all updated (how's it look?) :
RAM: SimpleTech (Simple Technologies) 256MB DDR PC2100- OEM $42 x2
Floppy Drive: SAMSUNG 1.44MB BLACK FLOPPY DRIVE Model# SFD321B/KEB - OEM, DRIVE $8
CD/DVD ROM: Lite On 48x24x48 CDRW Model LTR-48246SBlack OEM $58
Current Total: $979
---EDIT---
Just checked, my older RAM is SDR, not DDR. Crap, looks like I need to up it.
Changed price.
