No, *MY* new girlfriend!~
DFI NF4 SLi :o
OMG I want it.
|i7 2600k @ 4.8Ghz|Corsair H100i w/ NF-F12s|MSI P67A-GD65 B3|32GB Corsair XMS3|GTX 780 SLi|Skullcandy Slyr|1x250GB Evo 1x500GB Evo 1x1TB Evo|3x32LN5300|Win 8 Pro|Corsair Air 540|eVGA Super Nova 1300GS|
Really Cold Shark
Re: DFI NF4 SLi :o
Originally posted by OpStar
OMG I want it.
may need to find a buyer for my current setup
The expansion slots suck though.
You can't use the pci-1x between the SLi slots, dunno about the one on top.
Oh well, I'm still buying it and two 6800Us asap.
Re: ...
Don't forget the 1200W power supply you are going to need to run that bugger.
Intel i7 3.2GHz @ 4.24GHz
HIS R9 290X @1050MHz
Re: ...
I was about to post the same exact thing. I'll pass unless they redesign it. I'm plenty happy with Abit and Epox for all those years.
http://www.fquick.com/Dom
Viewsonic VX2025wm |Barton 2500+@2200Mhz(200x11) |Abit NF7-S ver2.0 |Radeon AIW X800XT |1GB DDR400 | 120GB WD |500W Raidmax PS |NEC 3500A | Lite-On DVD/CDRW |D-Link 5port+wireless switch/router |500W 10" sub(Rocket UFW-10) and cheap Bose bookshelves.
OMG it has 8 SATA PORTS!!!
Antec Three Hundred Two | Intel DP67BA | Intel 2600k | Corsair CWCH60 | CORSAIR Vengeance 16GB (PC3-12800) | PNY GTX 580 | Samsung 830 256GB SSD | WD RE4 2TB (WD2002FYPS) | Asus Xonar DG Sound | LG Blu-Ray Burner | Windows 7 Ultimate x64
Work:
Macbook Pro 15" Retina Display | 8GB Ram | 256GB SSD | Mac OS 10.8
I'm sure it's a nice performer but it's way too garish for me.
E6420 @ 400x8
AW9-D MAX
2GB Crucial Ballistix PC5300
eVGA 8800 GTS
It can't be THAT hard to set up a nuclear reactor in my closet, can it?
Yeah I know. I've emailed PC Power and Cooling about their "SLi ready" 750 watt psu, but it still isn't available.
I haven't upgraded either of my comps for awhile though, so I want to make this one worth it.
I'm not to fond of the colors either, but I know DFI makes quality enthusiast boards.
8 SATA!! w00t.
My main concern is the SLi of course, I only use one pci card, and that's my audigy 2.
Also, I heard from a pretty good source at work that the move to pci-express will come by way of the 6900 Ultra, nVidia's winter fresh which will up the core/mem speeds a bit.
We shall see.
Its going to be VERY expensive.
About 200 I'd guess, although nV states SLi boards should start at 150.
i hope ATI starts something like this, or else they would get murdered in preformance, and get taken off their preformance crown, also ATI X800 series actually require less power then the 9800 series, so thats a plus side on the power supply department
System 1:
Asus P5B Deluxe | Intel Core2Duo E6300 | (2x1gig) Patriot Extreme Performance PC2-8500 | MSI GeForce 260GTX | Samsung SyncMaster 225bw | Western Digital 640GB Caviar SE16 | LG DVD 16x | LG CDRW 52x24x52x | Windows XP Professional | Creative Labs Inspire T5400 5.1 Speaker System | Powered by PC Power & Cooling 750w | Coolermaster Stacker 830 SE | Cool by Thermalright Ultra-120 eXtreme Aluminum Heatsink
Really Cold Shark
Re: ...
8 SATA!! w00t.
We shall see.
here's what you can do:
get a bunch of smoke detectors
use the radioactive material to make a bunch of tiny breeder reactors
boil water with reactors
use steam to turn turbine
realistically, i wouldn't be too concerned about the present lack of a power supply, as none of it is really out yet, and i'm sure there will be a workable solution when the time comes.
Imagine that: a nuclear reactor in my closet. I'd be the envy of every geek around
I just saw this at ambforums and thought I'd be timely. Yeah, sure....
A64 3000+ (250x10 @ 166); Chaintech VNF-250; 1G Mushkin PC3200 (2-2-2-5);
Antec P160 w/Clear Side; Enermax/CoolerGiant 485W PSU; Seagate 160G PATA;
XP-90 w/Enermax 92mm; PNY 6800nu (350/750; 91.94 WQHL); Win XP Pro
Yeah I saw it at the [H] earlier.
