Help!
Results 1 to 2 of 2
Thread: Help!
    Catfish ac0403's Avatar
    Oct 2003
    Boston, MA
    Help!
    Well I formated my new Dell Inspiron 8600 and well now when I set the resolution to 1650x1080 (the setting I'm suppose to set it at with the WSXGA+ screen) everything is so small. I mean when I first received the laptop (before I formated) the resolution was the same but now everything is so tiny...I reinstalled the graphics drivers but it still didn't change anything...what am I doing wrong?
    My Rig:
    Lian-Li PC7B Plus|Dell 2005FPW 20.1" LCD|Enermax 420w Noisetaker PSU|AMD Athlon 64 X2 3800+ @2.5GHz|Thermalright XP-90|MSI K8N Neo4 Platinum|2 Gigs PC4000 OCZ Platinum RAM|ATI Radeon x800xl|74 Gig Western Digital Raptor (16MB Cache)|200 Gig Maxtor DiamondMax10|Sound Blaster Audigy2 Value|Lite-on 16x DVD Rom|NEC 3540 DVD Burner
    Dell Inspiron 8600:
    1.8GHz Intel Pentium M 745|1 Gig RAM|15.4"WSXGA+ LCD|64MB Nvidia GeForce FX Go5200|60 Gig Hard Drive|Intel Pro Wireless 2200 (802.11 b/g)
    Mako Shark mynameis's Avatar
    Indianapolis, IN
    Display Settings> Appearance > Set Font Size to Large
    Then Click Effects and select Use Large Icons.
    Does that do what you wanted it to?
    also in your web brower set your text size to bigger
    MacBook Pro 13-inch, 2.3Ghz i5, 8GB RAM, 640GB HD
    Desktop: i5 2500K (w/ CM Hyper 212 Plus) , 16GB DDR3, 2x240GB OCZ Agility SSD, 2x1TB in RAID0, 2xeVGA GeForce GTX 570, Corsair TX750M PSU, ASUS Sabertooth P67, Dell 2209WA eIPS LCD
    Home Server: Intel Pentium G630, ASRock H61M/U3S3, 4GB RAM, 80GB + 2TB HD
