Radeon 9500 Mod To Radeon 9700
System: AMD Barton 2500+ w/ThermalTake Silent Viking II |Epox 8RDA+ |1Gb KingstonHyperX PC3000 |Palit Daytona Geforce3Ti200 w/128mb ddr |Terratec DMX6Fire 24/96 |2x Seagate Barracuda IV 80Gb |Lite-On CD-RW 40/12/40 |Eizo Flexscan F730
Super Bunny Mod
easy enough to do if I had a hot air solder tool and solder paste, be cheaper to just buy the 9700 Pro
If your sig is longer than your post then type more.
how much would it cost to get a hot air sholder tool and solder paste???
i mean the difference between the cards here in canada is around 350$.. so if its cheaper then 350.. then yes go its better just to get the 9700 pro
System 1:
Asus P5B Deluxe | Intel Core2Duo E6300 | (2x1gig) Patriot Extreme Performance PC2-8500 | MSI GeForce 260GTX | Samsung SyncMaster 225bw | Western Digital 640GB Caviar SE16 | LG DVD 16x | LG CDRW 52x24x52x | Windows XP Professional | Creative Labs Inspire T5400 5.1 Speaker System | Powered by PC Power & Cooling 750w | Coolermaster Stacker 830 SE | Cool by Thermalright Ultra-120 eXtreme Aluminum Heatsink
Super Bunny Mod
the price difference is more like $250 Canadian
to get a cheap hot air setup you are looking at atleast $600 US from what I've seen
For a soldering gun and some solder wire?? Yikes.
Maybe I'm thinking of the wrong thing, but you can pick up a decent soldering kit for under or around 50 dollars. You could probably get one of those little 'pencil' soldering things even cheaper.
The question is do you really want to put the gun near your shiny new 9500??
"PS 3.0 utilizes a wide range of optimizations, from 64-bit frame-buffer blending to looping and dynamic conditionals for rendering multiple light interactions in a single pass without requiring a combinatorical explosion of precompiled shaders."
-Tim Sweeney
DNF > HL2
Ultra Great White Shark!!
www.myeducational plan.com-come see my plan to fix the USA educational system. I hope this is sig legal. Major Site Design Update on July 18, 2006. On June 18, 2009 passed the 10,000 post mark. December 24, 2009: Major Theme change and more....
Actually I was reading about the same thing on a polish site.
http://www.pclab.pl/?art=&sid=1572
What they did was use a normal soldering gun, with some silver wire added on to the tip of the soldering gun for extensions so as to enable working on a smaller scale (most soldering guns are too big for these little things.)
They got it working, although it took them a few attempts and the solder didn't look too pretty. But who cares how it looks, as long as it works, right?
As for putting a gun to a shiny 9500, well... the payoffs IS pretty damn good, i guess it all depends on how comfortable you are with soldering. Maybe someone can get more info on this as to the rating of the resistor used, and if you can substitute it with some radioshack resistor in case you wreck the original? That would be my biggest fear, wrecking the resistor somehow.
Maybe Tom's hardware can make a video on how to do this, they seem to like to make videos.
Sounds like one hell of a cool Mod to me.
Print is dead.
i used to assemble micro-pc boards with all those tiny resistors and capacitors. it's really not hard at all. all you need are some decent tweezers, a solder paste gun, and a soldering iron... just squirt a tiny bit of the solder paste, then hold the reistor in place and add the soldering iron to the flux/paste for about 1 sec. it's also good to have flux remover because that paste crap leaves flux everywhere... the end product is a very nice machine-made-looking solder joint. my work was such a masterpiece
also i'm not sure you can damage the resistor(wreck it) without trying to... usually it's the capacitors that will get messed up from crappy soldering skills(like overheating the joint)
i could be wrong, i didnt know too much of the scientific aspects of it, just how to do the crap efficiently.
damn, now i'm going to have to go out and get me one of these boards...
Batou's evil twin
 Originally Posted by Concerned Citizen
im a homosexual but i disliike obama for his non-*** policies
 Originally Posted by ua549
I'm happy for you. Why don't you go pick up a case of AIDS.
Super Bunny Mod
hot air uses guess what, hot air! there is no physical touching required. this tool would be the proper way to solder/unsolder SMT components and is really easy to do compared to trying to do it with an pencil iron. to unsolder a SMT resistor just go back and forth with the hot air for a couple seconds and pull it off with tweezers. to solder, dab some solder paste on the pads put the resistor in place and pass the hot air over it for a couple seconds and you're done
Print is dead.
cool, i never had access to one of those... how wide is the nozzle?
btw, when you're taught how to do it the old fasion way(as long as you have good tools) it's pretty easy
i couldnt imagine doing it with solder wire though... the paste gun is da business!
Batou's evil twin
Ok, from what i read, this is what i understood:
ONLY the Radeon 9500 with 128 MB Ram is able to mod to a 9700. The 9500 PRO can NOT be modded, nor can the 9500 64 MB.
Ok, i've found the 9500 128 MB selling at Ncix for $280 CAN. Now, the 9700 128 MB is selling at www.pccanada.com for $365 CAN. So i'd be paying $85 more, but i wouldn't hafta solder my card (which i'm real scared of doing). So really, its not THAT much of a bargain...
My System:
P4 2.40 @ 3.31 GHz & default Vcore
184 FSB
ASUS P4P800 with PAT and Turbo mode enabled
ATI Radeon X800 Pro @ Stock
1 GB DDR400 Samsung @ DDR460 (5:4 ratio)
Maxtor 200GB 7200 RPM 8MB
SB Audigy 2
Klipsch Promedia 2.1
Enermax 300W PSU
too lazy to bench with 3Dmark
Print is dead.
http://www.ncix.com/canada/
edit: more specifically: http://www.ncix.com/canada/productdetail.php?sku=8933
ok, so is this mod REAL or just a RUMOR?
or can no one verify?
Batou's evil twin
I do a fair amount of SMT work modding up hardware for testing. A much cheaper method that's about as easy as the hot air guns for 2 connection parts (resistors, caps, etc.) is to get 2 soldering irons. Hold one in each hand, and use the tips like tweezers on each end of the resistor. It will come right up. This doesn't work nearly as well as the hot air guns once you get to 3 pins or more though. To resolder, don't even bother with solder paste. There should already be plenty of solder on the pad, just place the resistor on the pads where it should go, and touch both ends at once with the soldering irons. Again - use them like tweezers. The solder will melt, and the resistor drops right down. If there isn't enough solder already there, use some solder wire and melt a little onto the pad.
It's really quite easy. If you are nervous, try it on a dead board first.
One by one, the penguins are stealing my sanity.
Be sure you get a GROUNDED iron! With non-grounded irons there is the potential for high voltage on the tip (for PCB's anyway). Don't go to RS for your iron. Invest in a solder station. Better control over tempuature, convienance of a holder and they are grounded. I recomend the WTCPS from Weller. Around $100. Made in USA and very good quality! I have two and wouldn't solder without. Reaches 800 degrees within 60 seconds as oppose to minutes with the pencil irons, maintains that temperature all the time.
I second the motion. A good Weller soldering station is a worthwhile investment if you do much electronics work.
