Unlocking the locked Bartons
Results 1 to 12 of 12
Thread: Unlocking the locked Bartons
    Hammerhead Shark Patrick00011's Avatar
    Sep 2003
    Bowmanville, Ontario
    I found a link to this website, that tells you how to do it... I'm not sure if everyone has already figured it out, or if anyone has posted this yet. Here ya go anyways:
    http://www.ocworkbench.com/2004/guid...rtonwk43-1.htm
    My System:
    Intel Q6600
    ASUS P5K SE / OCZ Reaper 6400 DDR-2 /Radeon HD 4850
    SoundBlaster Audigy 2 ZS / Klipsch Promedia 5.1 Ultra / Leadtek Winfast TV tuner
    Lite-On 40x12x48x / Lite-On 16x / Seagate Barracuda 160GB + 300GB
    Antec 1000PLUSVIEW / Nexus Fan Controller/ Samsung SyncMaster 213T + 275T
    Hammerhead Shark AutomaticErik's Avatar
    Sep 2003
    Austin, TX
    Well its about damn time someone figured out how to do it.
    Main Rig:
    Chaintech VNF3-250 | A64 3000+ @ 10 * 240 = 2.4Ghz | 512MB HyperX 3-3-3-10 | BFG 5900U 256MB -> 5950U | WD Raptor 36GB | Lite-On 811S DVD±R/RW
    Wife's Rig:
    Biostar M7NCD Pro | AXP 1700+ @ 10 * 200 = 2.0Ghz | 512MB Generic CAS2.5 | Radeon 9700 Pro | IBM 60GB | BenQ 48x12x48 Burner
    Server:
    Shuttle AN35N | Duron 700 @ 9.5 * 100 = 950 Mhz | 512MB RAM | nVidia GF4MX 420 | WD 8GB + 20GB Spanned Array | Iomega 8x4x24
    Buy Independent Music Online!
    Hammerhead Shark xelaeel's Avatar
    Feb 2002
    Toronto
    Ahh the good old pencil trick.
    XELA!
    Athlon XP2400+ @ 2343Mhz (11x213)
    SLK 947U w/92mm Tornado w/Nexus 205
    Abit NF7-S Revision 2.0
    OCZ PC-3200 Platinum 2x512MB @ 426Mhz
    ATI Radeon X850XT
    WD 60GB | WD 40GB | WD 160GB SATA
    Antec Plusview 1000AMG | Thermaltake PurePower 420W Active PFC
    Windows XP Pro SP2
    Creative Sound Blaster Audigy 2 ZS | Creative MegaWorks 550 THX
    Laptop 1: Dell XPS M1710 | T2500 | 2GB RAM | GeForce Go 7900 GTX | Hitachi 100GB 7200RPM
    Laptop 2: MacBook | T7400 | 1GB RAM | 120GB
    Sleeps with the Fishes
    Pittsburgh (please click here to donate $5 to city budget)
    Has anybody done this yet...call me crazy but I don't really feel like poking at my 2600 mobile with a pencil.
    Mako Shark Chuck232's Avatar
    Jul 2002
    WA
    The whole point is to make the mobo think that the proc is a mobile. As you can see, the mobiles are already locked, so there's no need for this mod on them. Only the "superlocked" AXPs.
    • -|C2D E6600|-|ASUS P5W DH|-|OCZ 2x1GB PC2-6400 Platinum XTC|-|Scythe Infinity|-|Seagate 7200.10 320GB|-|eVGA 8800GT 512MB|-|BenQ DW1655|-|Antec P180B|-|OCZ GameXStream 600W|-|LG L204WT|-
    • -|Dell XPS M1330|-|Core 2 Duo T7100|-|2x1GB DDR2 RAM|-|Hitachi 120GB 5400RPM|-|NVIDIA GeForce 8400M GS 128MB GDDR3|-|Intel 3945a/b/g|-|8X slot load DVD+-RW|-
    • Sharky Extreme 3DMark Team
    • site
    Uh there is a need to mod I can't get the multiplier past 12.5...
    Mako Shark slavik's Avatar
    Brooklyn
    about time?!
    sorry, but this is really old ... REALLY old (from last year, about a week or 2 after AMD started locking the chips)
    Activation? What activation?
    Quote Originally Posted by Geekkit (from ubuntu forums regarding 'goto' statement)
    Yep it sure does. So does crack cocaine. Existence is not a valid endorsement for being acceptable.
    Quote Originally Posted by Linus Torvalds
    Only wimps use tape backup: _real_ men just upload their important stuff on ftp, and let the rest of the world mirror it
    Sep 2003
    Austin, TX
    This is from January of this year chief.
    Main Rig:
    Wife's Rig:
    Server:
    Ok yea so back to the topic, how can I do this without risking killing my cpu? Do any kits exist?
    Jul 2002
    WA
    If all you need is the higher multipliers and the multiplier is already unlocked, this is not gonna help. (I don't think) All you actually have to do is the pin wire mod. Much less risky.
    • site
    Pin wire mod?!
    Thr pin/wire/pcb mod are three diff variations on the same trick. The version that is the least permanent is the wire mod and what I used to get my duron to run on a 16xFSB multiplier. What you use is very fine wire (typicaly from an extra ata100 ribbon). You cut the wire into ~1cm segments, bend them so they lay flat on the socket with the "tails" in the appropriate holes in the socket. This shorts the pins just as if the bridges were not cut.
    Some caveats to this method are...
    1)You have to remove the cpu to make muti changes
    2)You may have to reame out the holes in the plastic socket alittle to get the cpu pins to fit with the wire in there. I did.
    3)Some native multipliers may preclude specific other multipliers.
    You can figure it out by studying which pins create which mutiplier.
    The plusses to this technique are
    1) No resoldering to change multis.
    2) As permanent as you could want.
    3) allows high muliplier on lower FSB (some people still need this)
    4) it works to change voltage, mobile, or any other bridge setting.
    You should visit this page http://www.ocinside.de/index_e.html to play with their java pinmod applet. It lets you see the mod all three ways.
    And of course google around for some pinmod guides. There are many.
