I'd like to find out how many megaflops my computer can do...
Results 1 to 10 of 10
Thread: I'd like to find out how many megaflops my computer can do...
    Tiger Shark SmoothCorn's Avatar
    Toronto, Ontario, Canada
    I was reading about the top 500 supercomputer list. The fastest one can do 35 teraflops which is 35 trillion floating operations per second. I would like to find out how many flops can my cpu do... do any of u know where to get such benchmark?
    thx in advance
    Tiger Shark -Anomie-'s Avatar
    May 2003
    Encinitas, CA
    The Passmark Performance Test will give you a Mflops score, you can download a trial version here:
    http://www.passmark.com/products/pt.htm
    I've never used it myself though, so I can't give you any details.
    CPU: E6600 @ 3.35ghz
    Heatsink: Enzotech Ultra-X
    MB: EVGA 680i SLI 122-CK-NF68
    RAM: G.Skill 2GB 4/4/4/12/2T
    GPU: EVGA GTX275 (633/2268)
    HDD: WD 320GB SATA
    DVD: LiteOn LH-20A1 SATA
    Sound: HT Omega Claro
    PSU: Corsair HX620
    CPU: Opteron 148 Venus @ 2.93ghz
    HSF: Zalman CNPS9500
    MB: DFI Lanparty SLI-DR
    RAM: Crucial Ballistix 2gb 3/4/5/11/1T
    GPU: EVGA 7900GT OC Superclock (563/1646)
    HDD: WD Caviar 250GB SATA
    PSU: Corsair HX520 PSU
    Philadelphia, PA, USA
    Just about any decent cpu test will give you megaFLOPS (millions of floating point operations per second). Sisoft Sandra says my mildly overclocked XP2500+ gives me 3.2 gigaFLOPS.
    Desktop: Athlon XP 2500+/333 @12*180, 2x 512pc3200 DC, Epox 8rda (nforce2), X800 XL 256MB, WD 200 GB, Lite-On 4x +- DVDRW
    Laptop: Dell Inspiron, Centrino Duo 1.83ghz, 1GB Ram, 100 GB HD, 256 MB Radeon 1400, 17" widescreen display
    www.russsscope.net
    Great White Shark Moridin's Avatar
    Most X86 processors can get near their theoretical. In fact many of the computers on that list are in fact clusters of fairly ordinary systems. A P4 can do 2 FLOPS per clock cycle, so a 3.6 GHz P4 can do 7.2 GFLOPS (theoretical max). This translates into 4860 single processor systems or 2430 dual processor systems the reach that number. Since you only get about 90% efficiency, the real number is more like 5400 single or 2700 dual processor systems. (Which you can’t do yet because there is no 3.6 GHz Xeon)
    If we were using A64s we would need a lot more. It also peaks at 2 flops per clock, so you would need 8100 single processor systems or 4050 dual processor systems.
    The PPC processor in the Mac can do 4 FLOPS per clock but maxes out at about 70%-75% efficiency. At 75% you would need 4670 single processor, or 2335 dual processor 2.5 GHz G5’s.
    Hammerhead Shark Dantopia's Avatar
    Mar 2004
    Dallas Texas
    I'm a little confused then... Sandra shows my A64 doing 4088 mflops at 2 ghz... that translates to over 100% efficiency at 2 flops per clock... and the comparison shows a p4 3.2 doing 4330 mflops... that's either less than 2 per clock or very low efficiency... according to your analysis, the 3.2 pentium is much faster than the A64 and should be getting 90% of 6400 mflops, but it doesn't even come close.
    I could have sworn the A64 does at least 3 flops per clock... if you go by that and 2 for the Intel chip, then they both are running at 67-68% efficiency. That's the only way I can get the numbers to add up:
    4088 / 6000 (3 flops per clock, A64 3200 @ 2000 mhz) = 68.1% efficiency for AMD
    4330 / 6400 (2 flops per clock, P4C @ 3200 mhz) = 67.6% efficiency for Intel
    Maybe I'm missing something, but this adds up to me.
    AMD Athlon 64 3200+ Clawhammer | Asus K8V Deluxe | 2 x Kingston 512 MB | Leadtek GeForce 6800GT 256 MB | Seagate 160 GB SATA | Antec Truepower 430 | Mitsubishi Diamond Pro 2070sb 21" | Sound Blaster Audigy 2 Platinum
    Jul 2003
    Huntington Beach
    Dan, doesn't Sandra give you the effiency rating? Or is that only on the mem test?
    Friends don't let friends buy Dell.
    Originally posted by KaoTiK
    TBird is right.
    Mar 2004
    Dallas Texas
    Not that I can find, but then I need to update it, it's a few months old.
    Sushi vader545's Avatar
    Jan 2012
    Indy
    Peta flops
    According to the genus book of world records the world’s most powerful computer runs at 8.5 petaFLOPS.
    Aug 2004
    Urbana, IL
    The Blue Waters project at my campus is supposed to do 1 petaflop, but IBM backed out. They are looking into another supplier.
    Nice gravedig though, this is the stuff that is fun to dig up.
    PC: Corsair 550D
    4280k | Asus Rampage Gene | Mushkin 4x4GB | EVGA 780
    Intel 120GB SSD + 2TB Seagate | Seasonic 660 Plat
    2x Alphacool XT45 | Laing DDC | Bitspower
    Currently playing: Civ 5
    Last Game Beaten: Walking Dead
    Jan 2012
    Indy
    I kinda stumbled on it by accident I was doing research for my school project and found a (until today) new term for me. FLOPS I like it
