Random reboots
Results 1 to 5 of 5
Thread: Random reboots
    Jacksonville, FL
    Random reboots
    Can anyone tell me what the cause of random reboots would be? They don't happen very often, but are annoying when they do, especially when I'm in the middle of something.
    My system specs are as in my signature below.
    Could it be a short in the mobo, ram, or power supply?
    Thanks,
    Snuka
    AMD Athlon Classic 700 mhz (overclocked to 767 Mhz)
    MSI K7 Pro (6195) Motherboard
    256 MB Micron Cas2 PC-133 SD-RAM
    Western Digital 200 GB 7200 rpm HD
    Sony 1.44 Floppy
    TDK VeloCD 24/10/40 CD-RW
    Pioneer DVD/CD-Rom Drive
    Gainward GeForce 3 Ti 200
    SB Audigy Sound Card
    Cambridge Soundworks FPS 2000 Digital Speakers
    3Com 3C905C-TX NIC
    Dell 2001FP 20.1" Ultrasharp LCD
    Windows XP Professional OS
    Resident Audiophile XP1800's Avatar
    Feb 2002
    What kind of PSU do you have and how many watts is it? Also, do you have any means of monitoring your PSU's rails and system temps?
    Hammerhead Shark mrspm2003's Avatar
    Baytown, TX
    Could be a number of things. First thing I'd do, is get rid of that overclock. Check system temperatures, check voltage rails. Also, since you're on XP, go to control panel, system, advanced tab, startup and security settings button, and under system failure uncheck automatically reboot. Next time it reboots, it will give you a blue screen, get the number that the screen gives you, go to the Microsoft Knowledge database, and type it in, see what the problem is.
    XPS 400, quit the comp. scene. My new toy:
    2004 GMC Sierra SLT
    Z71
    6" lift coming very soon
    Jacksonville, FL
    I forgot to change it in the sig, but I did stop the overclock on both the processor and the video card for now.
    My PS is a non-named brand 300W PS (I'm at work so I don't know the exact name). I don't know how to monitor it.
    I'll make the changes to Win XP that were mentioned. I haven't been able to find a rhyme or reason to when the reboot occurs except that it seems to be more common when I close a window (especially IE).
    I'll post here what I find. In the meantime, any other suggestions or comments would be welcomed.
    Snuka
    Sony 1.44 Floppy
    3Com 3C905C-TX NIC
    I think if you want to go back to the OC spped you are going to have to have a good quality PSU uint.
