Chomp Chomp
Upgrade from Audigy 2 to Audigy 2 ZS
Hey guys, I was wondering if I'd notice much of a difference if I upgraded from the A2 to the A2 ZS. I'm using the Klipsch Ultras btw, if that makes any difference.
c2d e6600, gigabyte ga-965p-ds3 3.3, x1950pro, 3gb ddr2 800
Zoom-Zoom!
Not worth it, imho. The only new features in "actual" hardware are: higher SNR ratio, 7.1 support.
The rest of the new features (EAX4, DTS, THX console) are just features from newer drivers. I bet once the regular A2's are discontinued, creative will release a driver update for us A2 users with these features.
RIP SiS :(
That was also said about the Audigy 2 though. "Same features as the Audigy, just a higher snr with EAX HD and 6.1 support"
ATI Fanboy
Yeah, and the A1 and A2 are so different IMO. The A2 sounds a lot better.
.:|:. Thermaltake Xaser II A5000A Case
.:|:. OCZ PowerStream 470W PSU
.:|:. Chaintech VNF3-250 nForce3 250
.:|:. AMD64 3000+ 2.0Ghz @ 2410Mhz
.:|:. Zalman CNPS7000-Cu Copper HSF
.:|:. OCZ 1GB PC-3500 EB Platinum Edition @ 240Mhz 3-2-2-10 (2.9V)
.:|:. ATI Radeon x800 Pro 256MB @ 530Mhz/560Mhz
.:|:. Creative Audigy 2 ZS
.:|:. Klipsch Promedia 5.1 Ultras
3DMark01 - 25617
Join Fix-it.org Forums!
I own both the A2 and A2 ZS and while I like the ZS a little more than my old A2, I have to agree that it isn't worth it to "upgrade".
Gaming Rig:
| Antec Sonata Case | ASRock 4Core-Dual VSTA | Intel C2D E6420@ 2.54Ghz | 2GB G.Skill (4-4-4-12) | 74GB WD Raptor | 200GB Seagate Baracuda | MSI Radeon x800 XT-PE + HDTV Wonder | Creative X-Fi XtremeGamer | Klipsch Ultras 5.1 + SWS Sub | Dell 2001FP |
"Don’t waste your time on jealousy. Sometimes you’re ahead, sometimes you’re behind. The race is long and, in the end, it’s only with yourself." - Mary Schmich
I would say to atleast wait until it's released in OEM
Anyone know if you can use the breakout box of the Audigy 2 Platinum with the Audigy 2 ZS ?
Very hard to explain why you are mad, even if you are not mad.
I'm sure you can sell your A2s for at least 50 bucks, that would make it like a $30 upgrade
AMD Athlon 64 X2 4400+ || DFI Lanparty UT Ultra-D || 2gb OCZ PC3200 || ATi Radeon X1900XT || Western Digital 74gb Raptor || Dell 2001fp || Seasonic S12 600W
Chomp Chomp
eh, i'll think about it. i've only had it for less than 2 months. it's pratically brand new.
Save Ana
http://www.jpages.net/HelpAna.htm
Main Rig - All AMD build: R9 3900X | GB X570 Aorus Xtreme | 2x 8GB 3600CL17 Patriot ViperRGB | Sapphire Nitro+ RX 6900 XT | 256GB Sabrent Rocket NVMe M.2 (OS) | 4TB Samsung 860 EVO SATA SSD | 2TB Samsung QVO SATA SSD | 2x 1TB Samsung 850 EVO | 6TB WD Black | Corsair HX 1000 Platinum | CM H500M | Samsung LC49HG90DMEXX 32:9 | iFi Micro iDSD BL | LG SL8YG Soundbar | 64bit Win10 Pro
Zoom-Zoom!
Not a huge difference, but the A2 and up is better at music reproduction. Better DACS.
Save Ana
Chomp Chomp
i think the A2 sounds a lot better than the A1.
RIP SiS :(
Are you saying the A1 and A2 perform similarly in your opinion?
Or are you saying the A2 and A2ZS perform similarly?
I'm assume you meant the latter, not the prior; however, you've just misread the thread.
If so, I'm baffled at that statement and would love to hear your reasons.
Zoom-Zoom!
Oh, I'm saying that the A2 and up (A2 ZS) don't have a huge difference in soundquality compared to the Audigy 1, for most users. Some may notice a big difference, but the average user probably will only hear a slight difference. Upgrading to the hacked A2 drivers on an A1 might be a sufficient upgrade for some people.
