Duct: from open window to case
Ok, I'm thinking of taking some ducting, putting one side against an open window with a mesh thing, the other end to my side intake fan.
So, how safe is this? I'm pretty sure that it will suck cold air in, however since it is winter time I'm a little worried about perspiration and other water getting in there.
Bugs and dirt and stuff worries me the least, the window is high up (about 6 feet off actual ground) and the net/mesh thing is pretty fine.
Main Rig
+ AthlonXP 2500+ Barton (early week, unlocked); cooled by SLK900A w/ 92mm 64cfm fan + The Uberduct
+ 200x11, 1.725vcore, 2.7vdimm for everyday use; 210x11, 1.825vcore, 2.8vdimm max stable overclock
+ Abit NF7-S rev2 (Vantec Iceberq on NB)
+ 1x512MB Buffalo Tech PC3200 (CH-5)
+ Radeon 9500 Pro awaiting it's overclock
+ Seagate Barracuda 80GB 8MB cache 7200RPM HD#1
+ Western Digital 60GB 2MB cache 5400rpm HD#2
+ LG 52x CDRW
+ Samsung 32x CDROM
+ Allied 400W PSU
+ NEC FE991SB 19"
+ WindowsXP Proffesional
+ Sennheiser HD212 PROs
Private Jagermeister of the Cooler's Guild.
Old School OCer
I would be concerned about possible condensation problems.
Running Man
I bought tubing and the attachments from a hardware store to run from my window to my top blowhole during the winter. I have never had any trouble with condensation (even though I live in humid south Texas) and it lowers my temps a good bit. I cut plywood the exact width of my window and cut a hole for the tubing. I just simple open the window and place the wood (with tubing attached) and close the window onto the wood. All that's left is running the tubing to my blowhole. Give it a test run; condensation really shouldn't be an issue unless it's wet/raining outside. Sapasion usually (last time I checked) does a winter mod, but running a tube from his garage to his PC; you can ask him about that.
put a dip in the ducting so that if there is any water, it collects in it and not go into the computer, provided that the airflow is not too fast. Kinda like a sink trap.
Folding Team Member
I've done something similar yes and so does jamesavery22. I chose my garage over the pure outside precisely for moisture control myself.
Not a problem. Condensation occurs when air is cooled. Not when its heated.
Q6600 (GO), Zalman CNPS 9700, Gigabyte P35-DS3P, 4G Kingston 6400 C5, Leadtek PX 8800 GT ZL (650/1800)
2x WD 500GB SATA, ASUS + Pioneer DVRW, Antec Sonata lll case, Samsung 226BW 22"LCD, Logitech X540 7.1 speakers, Logitech G5 mouse
3GHz(9x333), stock Vcore, stock cooler
3.2GHz(8x400), +0.050vcore (gaming, 24/7)
3.6GHz(9x400), +0.150vcore (3DMark01 60769)
3.8GHz(9x422), 1.5v min(set) (3d01 62926, 3d03 42285, Crysis High 1680x1050 34fps) Ouch! She’s hot!
Here are some pics of my dryer hose mod, very easy to do and very effective.
Dryer hose mod pics
Gigabyte 7n400pro HARDM3NU FINAL Bios
Dual Boot XP/ME
xp1700axoa dut3c juhhb0302xpmw
11x200=2205.
Albatron Ti4200p 128mb
WD120gb, WD40gb
LiteOn 52x burner
Pioneer 10x dvd
(2) corsair 3200 xms 256@ 11-2-2-2.5
coolermaster hhc-001 heat pipe
650watts of psu 400for sys/ 250 for fans
19" Komodo monitor
Altec Lansing 5.1 speakers
Leadtek tv2000xp tv/fm radio card
Average load temp 52c/37c W/Dryer Hose Mod
Not exactly. Condensation occurs when warm air touches a cold surface. So when you have a duct with cold air going into a case, you have cold surfaces on the duct, in the case, and maybe the surface of the case. Lots of possible places for condensation to form.
So be very careful: don't allow the cold air the chance to make any surfaces inside the case cold (for example, duct it straight onto the cpu).
Also, PC fans aren't very strong - so depending on the fan and duct and outside environment, a little WIND outside might screw up your airflow.
Desktop: Athlon XP 2500+/333 @12*180, 2x 512pc3200 DC, Epox 8rda (nforce2), X800 XL 256MB, WD 200 GB, Lite-On 4x +- DVDRW
Laptop: Dell Inspiron, Centrino Duo 1.83ghz, 1GB Ram, 100 GB HD, 256 MB Radeon 1400, 17" widescreen display
www.russsscope.net
Warm air touching cold is when condensation occurs, just pay attention to the humidity in your area/home. This only happens when the air is holding enough moisture to do that. I know in my area, the air is so dry in the winter we need to run a humidifier in the house, probably making it unsafe for me. If you have dry air though, you should be safe, just pay attention to the days that aren't so dry.
