Revamped Home Theater PC Build and comments (lots of pictures) - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 20 of 20
Thread: Revamped Home Theater PC Build and comments (lots of pictures)
  1. #16
    Master of the obvious Adisharr's Avatar
    A room large enough for my head
    Quote Originally Posted by James View Post
    Yeah, 8GB of quality RAM is less than $90. So there is no reason not to do it.
    As for temps on the drives, the run in the high 20's, low 30's according to SMART.
    The design of the case is such that the airflow is actually pulled past the drives, thus creating a weak, but viable "active" cooling effect.
    Sounds like a solid design I'm liking that case, maybe I'll upgrade mine if I can fit the new case. The height of my old one is a bit smaller and just fits I think.
    ...WAIT FOR IT
  2. #17
    SenorDestro senorgotti's Avatar
    Apr 2001
    San Antonio
    Awesome thread but I kind of wish I never clicked on it. I always end wanting to spend more money on toys. What kind of speakers are you using with it?
    For a good time add SenorDestro to your 360 and Steam friend list. PSN: PoopRiot
  3. #18
    Quote Originally Posted by senorgotti View Post
    Well thanks.
    I'm using some crappo 5.1 channel surround speakers I inherited from a friend. Sadly, I haven't been able to save up enough to get the ones I want. As a note on audio, I'm so glad to have a new receiver. Setting the HTPC to 5.1 channel out, I get full 5.1 channel sound from my AC3 audio streams, whereas with my old setup I got expanded stereo with no sub channel.
    I'm now discovering that a lot of shows have a much more pounding base line than I originally gave them credit for. lol
    These are the ones I really want in the near/mid term:
    The Epic 80 - 500 7.1 channel Home Theater System from Axiom Audio
    My real dream is some Klipsch (always been a fan since they brought out their Promedia series for computer), but those are nearly 3x as expensive as the Axiom's.
  4. #19
    magniloquent prick
    if your cpu gets warm i can send you my conroe. such a waste of a slacr in that system.
  5. #20
    Quote Originally Posted by iamsostupid View Post
    It get's warm, but not hot. Stock speeds since it's an HTPC, and it runs in the mid-high 40's, sometimes low 50's. I've never heard the CPU fan ramp up.
