Home network goes for weakness
Results 1 to 3 of 3
Thread: Home network goes for weakness
    Catfish humblejohn's Avatar
    mental hospital
    Angry Home network goes for weakness
    cisco linksys wr54gt G with 3 computers. Acer laptop lists available channels(about 6) and I pick the strongest channel and everything seems fine. About 5 minutes later I find my computer moving at a snails pace and low and behold the channel has mysteriously switched itself from the strongest to the weakest and slowest. Other than this the network works fine.
    Can anyone help me here. Thanks in advance.
    dell 4600c w/19 lcd ; 2.4 p4, 80 g hd
    nvidia geforce 4 mx 440 w agp8x
    Great White Shark Un4given's Avatar
    So it sounds like you are saying your laptop has channels to choose from, and you select the one you want, but then it changes. Are you sure that you have selected the same channel in your router configuration?
    Intel i7 3.2GHz @ 4.24GHz
    HIS R9 290X @1050MHz
    mental hospital
    Cool Home network goes for weakness
    Sorry, I screwed up on the computer lingo again. I meant to say that the cisco router jumps from the strongest network which is mine and goes to another network that belongs to one of my neighbors. I believe there are about 6 other networks that the router picks up. Several are protected. It happens constantly. I would like to know if I can delete this other network(s) from my router so I don't have this problem. Both networks are unprotected. Thanks in advance.
