Which is the better system out of these two for games?
Novatech
4th gen Intel Dual Core I5 4200M 3.10GHz
NVIDIA GT 745M 2GB Graphics with Kepler architecture
8gb ddr3
Seagate SSHD 500GB Hybrid Drive
Dell
4th Generation Intel Core i5-4200U Processor
AMD Radeon HD 8670M 2GB DDR3
8gb ddr3
1TB 5400RPM SATA Hard Drive
Now I am not expecting blistering performance or being able to play the latest games, that doesn't bother me. Both these laptops are in my budget of around £500. The above specs aside, the Novatech is otherwise a much better laptop in my opinion but I don't know much about the graphics performance of the two cards here.
If I am you then Dell
Any particular reason?
"Watches You Sleep" Shark
http://gpuboss.com/gpus/Radeon-HD-86...eForce-GT-745M
I've never heard of Novatech so I can't speak to build quality.
Originally Posted by taggart6
wow Diablo 3 must really love Nvidia huh? 58.94 fps vs 17 fps for two similiar cards?!
It ran fine on my 4780 on my last system. No issues at full res.
Yep,dell is respected company
They aren't really in the UK ...maybe they are better now though.
I mean if you compare with Novatech .
I can't say either way until I see the parts lists for the Novatech, it all depends on the motherboard and PSU they use.
War... War never changes.
OK just saw laptop in the small print. Whats your budget, maybe we can help you find something better?
Defiant Shark
Novatech are a uk based company, I'm not sure all of whose machines they rebadge but they seem to be one of the few reasonable companies that are still on the go in the UK. I've had a few dealings with them previously and they seemed fine.
I used to like Dell as I found their machines were reasonably well designed for maintenance, the service manuals were free and the parts easy to get a hold of. However I've found their recent machines to be more difficult to maintain (less access ports, Torx screwheads) and the service manuals don't seem to be available any more. Having said that most laptops are the same these days, if looking for a laptop with decent performance it's worth checking the Dell Outlet as you can get a decent machine with a good discount if you have some patience.
John
Leviathan - AMD Ryzen 9 3900x, Noctua NH D15 Cromax, Corsair Vengeance LPX 64GB DDR 3200Mhz, Nvidia RTX 3080 10GB, 4TB SSD/26TB HDD. Fractal Design R6, Corsair RM850X
Rocinante - Intel i7 8750H, 32GB RAM, RTX 2060, 2.2TB SSD, Alienware M15 R1
Do you think I would be able to run the likes of Alan Wake, amnesia and Hitman Absolution with a gt745m? oh yeah and dark souls, must be able to play that..seeing as that runs on ancient ps3 hardware I guess I should be fine with that.
