XP on netbook
Results 1 to 5 of 5
Thread: XP on netbook
    Goldfish Pentium691's Avatar
    Aug 2005
    School
    XP on netbook
    I have Windows XP on a Samsung Netbook which I use as my travel computer. It has a lot of drivers and software on it that I don't know if I can get again.
    Microsoft has ended support for XP, but I am nervous to upgrade to Win7 or Win8.
    Will I need to get the drivers and software in order to upgrade, or am I worried about nothing?
    No Pentium yet!!!
    CPU : AMD FX-56
    Mobo: ABIT KN9 SLI
    Mem : 2 x 512 Kingston
    GPU : ATI 850XT
    SND : Fatal1ty FPS X-FI by Creative
    HDD : Barrucuda SATA 200Gb
    KEY : Fatal1ty
    MOS : MS Laser
    Quote Originally Posted by Pentium691 View Post
    Barring it being really outside-the-box hardware, usually a newer version of windows will include the drivers for most of the hardware that came before it.
    Dec 2014
    You'll haven't problems with upgrade your computer.
    Hammerhead Shark gateway's Avatar
    Apr 2001
    Home on the Range
    Quote Originally Posted by bestellen View Post
    I think I second this? You might have trouble installing 7 or 8 on that old laptop.
    If you're looking for good OS options for an old XP laptop (I've been doing the same), then consider a user-friendly, lightweight version of Linux such as Lubuntu (or Xubuntu if your computer can handle it).
    There's lots of good documentation on the install of these and you can even try it out before you install it (look for the documentation on Live CDs/USBs).
    Of course, if you have issues with the install, you could always ask =)
    (maybe a year too late, but you can't say I didn't try)
    [SGC Moderate Member]
    "I must not fear. Fear is the mind killer..."
    [Member of [PBLC]]
    "We believe if you can hack into your registry to change something, you should!"
    - The Screen Savers
    Houston, we have lift off!
    That is a hit or a miss. The manufacturer has to provide drivers to Microsoft to be packaged in the newer releases... whether the netbook manufacturer (in this case, Samsung) released such compatible drivers, you will want to check Samsung's website for that.
    MSI R6850 PE/OC (860/1100)
