program to check if the parts are used
Results 1 to 9 of 9
Thread: program to check if the parts are used
    Jan 2018
    Is there a program or some way to see if a new computer's parts are new or used?
    I remember a program that shows how many hours I've been using each hard drive.
    Does anyone know this program and something similar for the other computer parts?
    Mar 2018
    USA
    I think it can be understood by the appearance of the details, as well as with the help of the opinion of a professional
    Houston, we have lift off!
    Programs like Crystal Disk Info or DiskCheckup or HDDLife Pro or Everest...
    MSI R6850 PE/OC (860/1100)
    Apr 2018
    Quote Originally Posted by proxops-pete View Post
    To know the detailed.....
    Sep 2018
    I don't think it can be known for a RAM but it certainly possible for a hard drive and your motherboard. You don't even need a software to know that. Right before your system boots up, you need to go to the BIOS Setup. Generally, there is a tab where you can see when your machine is manufactured.
    Sep 2018
    Bangladesh
    Buying 2nd hand or ‘green’ parts can save huge amounts of money. But remember, these parts are 2nd hand, so it is unrealistic to expect them to be in ‘as new’ condition. However, unless otherwise stated, when supplied their condition should correspond to their description.
    Sushi FireLJ's Avatar
    Sep 2018
    Everest Portable is an all-in-one computer diagnostics and benchmarking program. It has the features you need
    Jan 2019
    Quote Originally Posted by Stinson View Post
    I don't think it can be known for a RAM but it certainly possible for a hard drive and your motherboard. You don't even need a software to know that. Right before your system boots up, HostGator DreamHost Bluehost you need to go to the BIOS Setup. Generally, there is a tab where you can see when your machine is manufactured.
    there is many programs in windows , he don't need to go to bios to see that
    May 2019
    It is better to ask the seller about it and then check visually and manually. And, surely, to buy from the checked sellers.
