Ryzen 3600, 3600, 3700x?
Results 1 to 5 of 5
Thread: Ryzen 3600, 3600, 3700x?
    Mar 2005
    NY
    Hi folks it's been about 10 years since I was last on.
    So my current rig from 2011/2012
    i7 2700k
    Corsair. H80i CPU cooling kit
    32gb ddr3 1333
    Samsung SSD
    GTX 760 in SLI
    Msi Mobo
    850W psu
    Antec 1200 full tower
    It's time to update my system because it's having trouble starting and shutting down just an alarm system overall. I was looking at a new rig and it seems like the AMD was the way to go. This was my plan rig and wanted to get people's thoughts on it:
    Ryzen 5 3600
    Rx 5700
    DDR4 3200 Ram 16GB
    There will be zero overclocking.
    My question is about getting which of these:
    3600, 3600x or 3700x
    5700 vs 5700xt
    I'm not sure if it's worth putting the money into the 3600x, 3700x or put that extra for the 5700xt.
    My PSU is good enough
    MOBO: GA-Z68X-UD3H-B3
    CPU: i7-2700K @3.5 ghz
    RAM: G.SKILL Ripjaws X 32GB (4 x 8GB)
    CPU COOLING:Corsair Hydro H80i
    VIDEO: MSI TF 2GD5/OC GeForce GTX 760 OC N760 in SLI
    HDD: Intel 320-160GB SSD
    HDD: Samsung 840 250GB SSD
    MEDIA: Plextor Dual DVD
    PSU: CORSAIR HX750W
    CASE: Antec Twelve Hundred V3 Full Tower
    OS: WIN 7
    10 x64 Home Premium
    Monitor: AOC ,32" curved 1440p
    Houston, we have lift off!
    You are right. But the key point/question is will you be gaming heavily?
    If so, I'd go with one of the X ones... mainly because they have higher clock and OC better...
    As for the video card, if you are going from the one in your sig (GTX 760 in SLI), I'd say even 5600XT will be good.
    If you want 5700 series, I'd skip the XT. That's my 2 cents.
    MSI R6850 PE/OC (860/1100)
    Mar 2005
    NY
    Thanks for the feedback.
    The games I will play want a gtx 970 or equivalent (insurgency sandstorm, squad, division 2, breakpoint.
    For the price difference I might as well go with the 5700. I understand that the extra erag on the x is not worth it compared to the amount of heat it generates.
    So, would you put the money on the ryzen 3600x or Rx 5700xt or just save all my money and stick with just 3600 + 5700
    If I go with higher I will either upgrade the CPU X or gpu xt but not both.
    PSU: CORSAIR HX750W
    OS: WIN 7
    10 x64 Home Premium
    If you invest money in either video or CPU, I'd choose video/GPU anyday... the bottleneck always seems to come down to the video card.
    I'd think that 3600 & 5700 is just dandy... but if you spent more, get 3600 & 5700XT
    Great White Shark mikeysg's Avatar
    May 2003
    What mobo are you loking at? B450's like the MSI B450 Tomahawk MAX or Mortar MAX would save you some money to put into a better CPU/GPU. You don't really need an X570 unless you want/need PCIe4.0 and NVMe M.2 Gen 4, a 3700X + B450 Tomahawk/Mortar MAX + RX 5700/5700XT would be a very good starting point. Though I dislike nVidia, with framerate gains in DLSS 2.0, perhaps an RTX2060 Super if you can swing it....
    Save Ana
    http://www.jpages.net/HelpAna.htm
    Main Rig - All AMD build: R9 3900X | GB X570 Aorus Xtreme | 2x 8GB 3600CL17 Patriot ViperRGB | Sapphire Nitro+ RX 6900 XT | 256GB Sabrent Rocket NVMe M.2 (OS) | 4TB Samsung 860 EVO SATA SSD | 2TB Samsung QVO SATA SSD | 2x 1TB Samsung 850 EVO | 6TB WD Black | Corsair HX 1000 Platinum | CM H500M | Samsung LC49HG90DMEXX 32:9 | iFi Micro iDSD BL | LG SL8YG Soundbar | 64bit Win10 Pro
