Hi, sorry for the tardy response, been busy with life ....and games, as for what to expect, seeing you have a B450 mobo, it now boils down to whethereyou have a Ryzen 1xxx, 2xxx, 3xxx or 5xxx series CPU, the first two are kinda showing their age in modern gaming, while the latter two are still pretty good. If you have a Ryzen R5 2600X and higher, its still good enough, just don't expect sky high framerate, okay?
So, first part hinges on your CPU, second part is your GPU, while an RTX 3060 would certainly improve gaming performance, it really depends on the game (or more precisely, the game engine used). Some games that are highly dependent on GPU prowess, you would see and improve in framerate improvement, and perhaps at higher graphics setting too. While other games, usually online shooters like Fornite and Valorant, might require a faster CPU for improved framerate. That is not to say you won't see an improvement in framerate, it might be negligible considering the GPU jump from a GTX 1060 to an RTX 3060.
How much will the RTX 3060 cost you? I can find an RTX 4060 8GB at similar pricing, NOT at the lower range of RTX 3060 pricing, more like in the middle. The RTX 4060 is a fair bit faster than the RTX 3060, and uses less power at the same time. An alternative would be the RX 6700 10GB at 250USD:
https://www.bestbuy.com/site/xfx-spe...?skuId=6523730
It outperforms the RTX 3060 (though it consumes about as much power) and is closer to the RTX 4060 in rasterize gaming, just throwing this and the RTX 4060 out there as alternatives, up to you to decide.
Save Ana
http://www.jpages.net/HelpAna.htm
Main Rig - All AMD build: R9 3900X | GB X570 Aorus Xtreme | 2x 8GB 3600CL17 Patriot ViperRGB | Sapphire Nitro+ RX 6900 XT | 256GB Sabrent Rocket NVMe M.2 (OS) | 4TB Samsung 860 EVO SATA SSD | 2TB Samsung QVO SATA SSD | 2x 1TB Samsung 850 EVO | 6TB WD Black | Corsair HX 1000 Platinum | CM H500M | Samsung LC49HG90DMEXX 32:9 | iFi Micro iDSD BL | LG SL8YG Soundbar | 64bit Win10 Pro
