By the Power of Greyskull
Just admit it you want to brag
Intel I9 14900K|ASUS - MAXIMUS Z790 HERO|ASUS GTX 1080 Ti|64GB G.Skill|(3) Samsung 990 Pro 4TB NVME |Custom water cooling||Alienware AW3423DW 34" OLED
288TB Plex server (UNRAID)
(16) WD Red Pro 20TB
-Core i7 [email protected] (H2o)
-ASUS Rampage III Formula
-Radeon HD6990 (950/1350) (H2o)
-24GB Vengeance@1760 (9-10-9-28-1T)
-(2x) OCZ Vertex LE 100GB (raid 0)
-(2x) 2TB WD Black
-X-Fi Fatal1ty Pro
-Corsair HX1000
-Corsair 800D
Ohh.. Well I wont be much of a help then... No AMD here
So when are you going to push that video card harder for a 21.5 score?
i got mine at 2.2 GHZ and its still running like a dream i dont want to push it to its max yet. It is only runnig a 1c or 2c hotter than when i ahve it at 1.8GHZ so i am sure i can push it more .
Free Computer Magazine Subscriptions
PC:
AMD Barton 2500+ @2.2GHZ(200x11)
FAN Zalman CNPS3100+
MSI K7N2 Delta Series
512MB Kingston HyperX DDR PC3500(@400)
ATI Radeaon 9600 Pro (470/329)
WD 120Gig @7200RPM
48X CD-RW
on board sound and Lan
WINXP
workstation: athlon xp-m [email protected] | epox 8rda+ | 512mb | seagate 80gb+160gb | arch linux
web server: athlon xp 1600+ | epox 8k3a+ | 256mb | maxtor 30gb | debian linux
SUPER PI? Also where do i DL prime 95 thanks.
PC:
WD 120Gig @7200RPM
48X CD-RW
WINXP
prime95 is here.
Colossus turned us on to SuperPi, actually. (at least i think it was he. ) it's a pi calculation benchmark. i don't have the direct link anymore, but it's linked to on this page (search down): http://www.myownlittleworld.com/pi/pitable.html
2.2 ghz @ 2.1 vcore....pitiful if you ask me.
kirkyg
System 1:
Pentium 4 2.4C @ 3.45 Ghz
Abit IC7 - 875P chipset
2 x 256 PC 3500 Corsair XMS memory
ATI Radeon 9700 @ 380 core / 320 memory
Modified Lian Li PC601 Aluminum Case (silver)
Cooling - 120 mm Top blow hole fan, 120 mm side intake, 80mm smartfan cooling an SLK-900 U, 2 80mm intake in front, 2 80mm exhaust in back, Dual fan power supply
Can only get mine to 2.45ghz before it starts crapping out on me.
AMD Opteron @ 2.94ghz
2x G.Skill Extreme PC4000 @ 268 FSB 1:1
Sapphire X1900XTX @ 690 / 1600
Asus A8R32-MVP Deluxe
XFi Xtreme Music
2x 160gig Seagate's Raid-0
200gig Seagate HD
16x Samsung DVD Burner
52/24/52a Plextor Burner
2005fpw Dell LCD 20.1"
Logitech MX1000 Mouse
KINGWIN ABT-600CW 600W Power Supply
Windows XP Pro SP2
CoolerMaster Case
Originally posted by serotone9
prime95 is here.
thanks man appreciate it i will have to DL those and run the tests
PC:
WD 120Gig @7200RPM
48X CD-RW
WINXP
btw, SuperPi is 45sec, which is 5 seconds faster than my 2100+ at 2.3.
I went down about 3 secs on SuperPi moving from 2100+ to 2500+ at the
same Mhz. Now, my FSB went up from 195 to 215, but SuperPi, as fa
as I know, is dependent on raw CPU speed (not??)
Anyway, I don't think I see enough written here about how Barton
outperforms Tbred clock-for-clock. Not by a huge amount, but it DOES.
A64 3000+ (250x10 @ 166); Chaintech VNF-250; 1G Mushkin PC3200 (2-2-2-5);
Antec P160 w/Clear Side; Enermax/CoolerGiant 485W PSU; Seagate 160G PATA;
XP-90 w/Enermax 92mm; PNY 6800nu (350/750; 91.94 WQHL); Win XP Pro
it totally does. remember the anandtech review from earlier in the year? the barton equals or surpasses the t-bred at the same clock speed every time. and for general use (what most people probably use their computers for at least 50% of the time), the barton is king.
Yeah, that was one of them. BTW, I went thru the scores randomly
to see that Barton was right up there. I have mine running at 3200+
speeds, so it'll fare purty good. Now, not to forget that if I o/c,
then I have to take into account that the other CPU's will as well,
to be objective. Still, a $171 chip/mobo ain't too shabby....
Avanti
I'm running my 2500 at 2230 solid. With the rest of my components so fat, a soldier in BF 1942 turned around yeterday and screamed at me " Slow this D*mned thing down! " Heeheehee
1.asrock z68 extr4;2500k@4400;cm hyper212+;2-5850crossfire;8g gskillddr3-1600;cru300ssd sata3-64g,wdb500gsata3;x-fi titanium fatality pro;antec tpII 750w;win7-64 hp;hannsg hh241
2asus p8z68-v pro/gen3 ;2500k@4426;corsair h60;sapphire 6950;intel x-25m-80g;intelx25-v40g;samsng f3 500g;8g gskill ddr3;asus xonar dx pci-e;win7 hp64;antec grn 750W;acer 23"
