upgrade to radeon 7000 64 MB AGP???
I currently have a radeon 32 mb ddr card on an athlon xp 1700+ with 256 MB pc2700 ram. I saw an ad in compusa for the radeon 7000 64 mb agp for $50 after rebate. Would this be a worthy upgrade? Or should I save my cash for the radeon 8500LE?
Phenom II 550BE . Biostar TA-785G3. 512MB HD4850 . 2 GB DDR3 . WD 250 GB Sata . Razer AC1 . 500W psu. Win 7 Home
8 Wheels Move The Soul
Re: upgrade to radeon 7000 64 MB AGP???
Save up for the 8500. The 7000 is the hobbled version of the classy 64MB Radeon (7000 used SDR, Classic used DDR), but I'm not too sure about the clock speeds.
But you'll still be much better off with the LE. It's under $100 anyways, and can be bumped up to 8500 speeds if that's your thing.
#1) Big Box
Core 2 Quad Q9550 - Asus P5Q3 - 8GB DDR3 1333 - GeForce 550Ti - Win 7 Pro
#2) IBM Thinkpad R51
Pentium M 1.6GHz - 1GB PC2700 - 80GB - Win 7 Pro
#3) Macbook Pro
2.4GHz Core i5 - 4GB - OS X Lion
#4) Rollerskates
Bont Quad Racer Carbon - Sure-Grip Avengers - Qube 8-Balls
Now Playing: Forza 4, Wipeout HD, Dead Space 2 (again!)
Ah - much thanks. i'll wait then.
No, that's not an upgrade. The 7000 is actually worse. You should get the radeon 9000 @ newegg.com, or do what Ashpool says and wait to buy the 8500. Your proc is yearning for a worthy vid card, anything less would be uncivilized.
Man With Nothing To Lose
Yeah, don't get the Radeon VE. It has something like 2.9GB/sec of memory bandwidth and has half the fillrate of the Radeon 32MB DDR not to mention it has no hardware T&L.
*edit* For Future refernce a Radeon 7000 = Radeon VE
"If everything you try works, then you are not trying hard enough." - Gordon E. Moore
Desktop:
AMD Athlon XP [email protected] (11.0x210) | EPoX EP-8RDA+ | 512MB Crucial PC3200 | VisionTek GeForce4 Ti4600 | nVidia SoundStorm 5.1 | 160GB 7200RPM Western Digital | 48x/12x/48x Lite-On CD-RW | Lite-On 16x DVD-RW | 19" NEC AccuSync 90
Laptop:
Intel Pentium-M 1.4GHz ULV | 512MB Nanya PC2700 | ATi Mobility Radeon 9200 | 60GB 4200RPM Toshiba | 8x/16x/10x/24x Matshita DVD/CDRW | 12.1" Sony XGA TFT
SharkyExtreme 3DMark Team
Ah I understand now. Thanks so much guys! I'll save up for the radeon 8500.
Just to clear things up, the 7000(VE) is also DDR but only 64bit wide instead of the 128bit DDR of the radeon32. Effectivly half the memory bandwidth of the radeon32DDR.
Also its slower 250MHz ramdac and lack of a hardware T&L unit make it no prettier or faster than a MX200 which is only 64bit SDR.
If you ask me $30 is too much for this card
Q6600 (GO), Zalman CNPS 9700, Gigabyte P35-DS3P, 4G Kingston 6400 C5, Leadtek PX 8800 GT ZL (650/1800)
2x WD 500GB SATA, ASUS + Pioneer DVRW, Antec Sonata lll case, Samsung 226BW 22"LCD, Logitech X540 7.1 speakers, Logitech G5 mouse
3GHz(9x333), stock Vcore, stock cooler
3.2GHz(8x400), +0.050vcore (gaming, 24/7)
3.6GHz(9x400), +0.150vcore (3DMark01 60769)
3.8GHz(9x422), 1.5v min(set) (3d01 62926, 3d03 42285, Crysis High 1680x1050 34fps) Ouch! She’s hot!
