Cube is finished for real this time.
Results 1 to 2 of 2
Thread: Cube is finished for real this time.
    Hammerhead Shark joerg's Avatar
    Jun 2002
    Salina Kansas
    Well it is comlete just the little tweeks and stuff left but nothing to really change its appearence. Here are the pics
    http://joergon.i8.com/cdrom-covers.jpg
    http://joergon.i8.com/chassis.jpg
    http://joergon.i8.com/Inards.jpg
    http://joergon.i8.com/On-desk.jpg
    i am happy with how it turned out except for how much it weighs and how noisy the fans are it sounds exactly like a vacum cleaner when they are all running and to get an idea of how powerfull the fans are i will give you my temps running my 1600+ at 1.875 i am getting 34idle and 41 max load but even with out the main fans on i am getting 37 idle 46load so i dont think they will be on to often maybe in the summer because they would easily keep me cool. Also the lights worked perfectly and are still very cool after 3 hours so i could recomend rope light to anybody. All in all the case is better than my old one for cooling and it is fun to make a custom case so like i said earlier i am happy. It costed very little compared to most mods too 5 for plexi fans were free as was all the metal and the light switch cover and switches costed 5 the paint for the cdroms was 2 and the old case i tore up for the hdd rack and rear card slots was 7. And for 20 dollars i think it looks awsome. Well anyway i am going to go submit it to vhgallery now. So what would you guys rate it as from 1-10 i think in all honesty i would give it a 7.5 becaus eof the noise and hwo big it is.
    [email protected] Epox 8rda+ 512megs Crucial pc2100 @ 212x12 Custom Case GF4 ti 4200 1 tera byte hdd space.
    remember me? number1sixerfan's Avatar
    Sep 2002
    Ohio
    Man that's cool. With all that spare time you could just build me one.
    As for the noise, get a rhebus. I like the on/off switch. Looks original.
    Because of noise, I'd rate it a 8.5; if you get a rheobus I'd jack up the score to 9 or 9.5
    Good Work.
