Cocodrie Shark
Fastest CPU for 8KHA+?
OK, I did a search and couldn't find an answer to my question so...
What is the fastest CPU I can put in my 8KHA+?
"The only thing necessary for the triumph of evil is for good men to do nothing. "
"He that lives upon hope will die fasting."
Benjamin Franklin
266MHz FSB 2600+.
"Fighting for peace is like f**king for virginity."
"To the world you may be somebody, but to somebody you may be the world."
Cocodrie Shark
Benjamin Franklin
You can get a 2600+, but make sure it has a 266fsb not 333. Also make sure you have the newest BIOS for it.
Epox 8KHA+
Antec True430W
AMD XP 2400+ @ 2.2
SLK-800 w/ Vantec Tornado
Sapphire 9800pro
768MB Crucial DDR266
Sound Blaster Audigy 2
60 gig Western Digital ata100/7200
Lite-On 16x DVD
Samsung CDRW
Klipsch 4.1 Speakers
KDS 19" CRT
Originally posted by CajnDave
Hey Dave, I have an 8KHA+ in my own machine right now. Considering that the XP1500+ was the first chip I put in it, I'd say it's not all that shabby that I can put an XP2600+ into this same mobo. You CERTAINLY can't put a P4 2600MHz into one of the first P4 mobos, so that's a bit of food for thought. I'd say I've gotten pretty damn good mileage out of this board, and although I'm going to buy an EPoX NForce2 mobo as my next upgrade along with a 333MHz or 400MHz (we can hope) Barton, I'm still going to keep the 8KHA+ for a while and put an XP2600+ chip in it when they're cheap enough.
Happy holidays!
AMD Phenom II X2 550BE@X4 (4cores unlocked) 3.82GHz (1.456V); Zalman CNPS 10X Quiet; 4Gb Kingston DDR2-800; 2x4850 512MB Crossfired
In response to some positive words about Stalin: "If Hitler invaded Hell, I would at least make a favourable reference to the Devil in the House of Commons." -- Winston Churchill
Cocodrie Shark
Didn't know AMD made a 266/2600+, thanks y'all.
Benjamin Franklin
Happy holidays!
Hmm, I wonder why you had to bring the P4 into this?
But you're not entirely correct there, you can get Socket 423 to Socket 478 adaptors (similar to the 'Slotket' for the Slot 1 based mobos) and you can fit a 400MHz FSB P4 into any old P4 mobo.
Cocodrie Shark
Just Ordered a 266/2400+. Hope it works...and OC's.
Benjamin Franklin
Evil Monkey Shark
it should do both for ya if you've got some really good cooling 2.3-2.4Ghz is possible with that chip. let us know how it goes.
- 2xRaptor 150GB RAID-0
Dave? Dave?! Dave's not here...
Cocodrie Shark
I've got good cooling. My 1600+@150 runs 95deg F.
Benjamin Franklin
Running Man
Is this for the custom case computer? If so, how's she holding up, and has your dividers worked well in the long run? I loved the idea way back when, and I saw the pics, but I was just curious how it all turned out this far down the road.
If you have some good ram you can get a nice overclock out of that board... heck I did 185Mhz FSB on that board when I had it.
Cocodrie Shark
It works like a dream. The only thing I changed was to remove all the exhaust fans. It runs alot cooler without them even though they put out more CFM than the intakes.
I've slacked about actually finishing it to a level to show. But I will do it very soon.
I'm running 512megs of Corsair XMS PC2700 if I remember correctly.
Benjamin Franklin
I seem to remember that The 8kha+ would only handle up to the Thoroughbred A core. Is this actually the case. I thought that the Thoroughbred A core stopped at 2200+. So what you guys are saying is that the 8kha+ will still support newer cpu's as long as they are the 266mhz FSB variants???
there should be no difference between T-bred B and T-bred A, with regards to compatibility. of course i may be wrong, and maybe someone knowledgeable like moridin might correct me. major differences were between tbird and palo, with arch differences, but i think T-bred was just a process shrink.
also make sure appropriate multipliers are available.
Check this out.
ftp://ftp.epox.com/motherboard/suppo...pu-support.pdf
Here's a link to Epox's CPU support manual. It will tell you what CPUs work with what Epox motherboards. Very informative.
My rig:
Antec SX1040 performance II Tower | AbitP IS7 mobo | P4 2.4B @ 3.1 ghz /175 fsb | Stock P4 heatsink cooler | 512MB PC3500 Corsair XMS cas 2 | 512MB PC3200 OCZ cas 2 | 120 gig WD (7200 rpm) & 200 gig Seagate Barracuda (7200 rpm) | BFG 6800 GS | Creative SB Audigy 2 | Lite-On 16x DVD ROM | LITEON DVD writer+ -RW DUAL 8X4X/8X4X CDRW 40X24X40 | 430 watt "Truepower" Enermax PS | Klipsch Promedia 4.1's | Logitech® MX™510 mouse | G15 Logitech keyboard | 22" Samsung SyncMaster 225BW
