Corsair to offer "TwinX" matched pair memory for DCDDR.
Page 1 of 3 123 LastLast
Results 1 to 15 of 39
Thread: Corsair to offer "TwinX" matched pair memory for DCDDR.
    Great White Shark Un4given's Avatar
    Looks like a good idea to me.
    Corsair Announces TWINXTM Memory Kits
    Fremont, CA, January 13, 2003: Corsair Memory, Inc., an industry leader in ultra-performance DDR DRAM modules for gaming and overclocking applications, has announced that it is now offering a new product family designed for use in motherboards with two memory channels. Such motherboards include those based on Nvidia's Nforce2 chip set and Intel's E7205 ("Granite Bay") chip set.
    The TWINXTM memory kits are composed of two low latency memory modules that have been tested as a pair in an Asus A7N8X dual channel motherboard. The matched pair of modules are then physically packaged together, guaranteeing that the customer receives a product that has been verified in the dual channel environment. These memory kits are available in sizes of both 512 MByte (two 256 MByte modules) and 1 GByte (two 512 MByte modules), at speeds of either 333 MHz (also known as PC2700) or 400 MHz (also known as PC3200). These configurations are summarized below:
    TWINX512-2700LL: 512 Mbytes, 333 MHz, low latency module pair, kit consists of two matched CMX256A-2700LL DIMMs
    TWINX512-3200LL: 512 Mbytes, 400 MHz, low latency module pair, kit consists of two matched CMX256A-3200LL DIMMs
    TWINX1024-2700LL: 1 Gbyte, 333 MHz, low latency module pair, kit consists of two matched CMX512-2700LL DIMMs
    TWINX1024-3200LL: 1 Gbyte, 400 MHz, low latency module pair, kit consists of two matched CMX512-3200LL DIMMs
    "TWINX memory kits take the guesswork out of dual channel motherboards," stated John Beekley, Vice President of Marketing at Corsair. "By using modules that have been 100 tested, as a pair, in this environment, the user can be confident in the performance and stability of his or her dual channel system."
    Further information and specifications on this product and other XMS products can be found at Corsair's web site (www.corsairmemory.com/xms/). These modules can be purchased through Corsair’s authorized sales channels listed at http://www.corsairmemory.com/xms/xms_sales.html.
    About Corsair Memory
    Corsair Memory, a member of JEDEC, has been a leader in the design and manufacture of high speed modules since 1994. We have earned our reputation as being the first to market with leading-edge products supporting new computing platforms and technologies. Corsair supplies memory for applications ranging from mission-critical servers to ultra-high performance gaming systems. The performance and reliability of Corsair memory products makes them ideal for the high bandwidth internet infrastructure.
    More information on Corsair is available at www.corsairmemory.com.
    Intel i7 3.2GHz @ 4.24GHz
    HIS R9 290X @1050MHz
    Hammerhead Shark MarcDaddy's Avatar
    Mar 2002
    Im lucky i have no problems with my Corsair XMS 3200 in Dual Channel, thanks for the info ill be sure to tell my friends and foward the link on.
    FX-53 @2580 Mhz FX-57 INBOUND
    2 Gigs of OCZ dual channel
    2 XFX 7800 GTX OC stocl 490/1300
    3dmark 05 intial run of 12140
    http://service.futuremark.com/compare?3dm05=1050155
    Mako Shark Paladyr's Avatar
    Mar 2001
    Cinci, OH
    Seems like a good way for them to justify a price hike... so instead of consumers buying 2 sticks of their RAM seperately that will without out a doubt run perfectly fine in a DC environment, they can now buy 2 sticks in the same box at a higher price because they have been "tested" to work together. I didn't even know their was any "guess-work" involved in buying RAM for DC mobo's????
    Core 2 Duo w Radeon 4850, Droid Phone, Mits HD1000U projector
    Minot, ND
    Hrmm, right after i get my second 512mb XMS pc3200 stuck in...
    thats ok, they both run fine at 190fsb
    maybe i should update my sig?
    My Site -=[http://hzrd.us]=-
    Puter #1
    Athlon XP 2600+ @ 2.2GHz 11.5x190 | 2x512mb Corsair c2 3200 | Radeon 9800 Pro |Asus a7nx8 | WD 120GB/ Seagate SATA 120GB x 2
    Puter #2
    T'bird 1000@1224 | 768 Crucial PC133 | GeForce2 MX 32mb eVGA | Abit KT7a-Raid | 40gb ata/100 WD | Sound Blaster Live!
    Folding Team Member sapasion's Avatar
    Folding@Home
    I knew all my waiting around to buy ddr400 would eventually pay off
    Sleeps with the Fishes Almost Famous's Avatar
    Oct 2002
    Upstate NY
    I'd be surprised if you did have problems running your XMS3500 (in your sig) @188Fsb, as you're running it below it's rated speed. Try doing 200+Fsb and see how it runs
    hmm... where is this being sold? not at newegg thats for sure
    Hammerhead Shark ryandinan's Avatar
    New Haven, MO USA
    What is dual channel DDR??? I've been asleep for a half hour....
    -Ryan
    Core 2 Duo E6400 @ 3.2GHz (8x400)
    2GB Corsair XMS 6400 DDR2 (800MHz)
    Asus P5B (802 BIOS)
    Sapphire Radeon X1900XT 256MB
    Thermaltake ToughPower 700W PSU
    remember me? number1sixerfan's Avatar
    Sep 2002
    Ohio
    -Ryan
    http://www.kingston.com/tools/bits/bit33.asp
    That should get you up to date.
    I was starting to get worried about Corsair's future because of it's overclocking with nforce2 boards. I'm relieved now.
    Isnt corsair shooting themselves in the foot by implying that their regular sticks of ram doesnt run at implied speeds?
    Tiger Shark KommisMar's Avatar
    Oct 2002
    Hunting the Wumpus
    Any word on a price?
    My Rig: A computer that runs Windows.
    My Page
    Minot, ND
    No, b/c when you run dual channel, it's best to have two of the exact same piece of ram in order to get the best errm, mix for lack of a better word @ 1:12am and just getting offa work.
    Since they are going to "match" them already... you dont have to worry about compatibility and the such. Should OC quite well together.
    Puter #1
    Puter #2
    Hammerhead Shark tYteaZzAzN's Avatar
    Sep 2001
    San Jose, California
    Neato! But i think i'd still prefer buying two seperate sticks of pc3500 or kingston hyperx 3500. Great way to ensure optimal performance though
    Knight of the OC Crusaders
    Private tYteaZzAzN of the Coolers Guild
    CASE Lian-Li PC-75B w/ window PSU Antec 550W TruePower CPU AMD Athlon XP 1700+ T-bred B @ 2400mhz HEATSINK Custom Watercooling Configuration *listed below* MOTHERBOARD Abit NF7-S rev.2 MEMORY 2 x 512mb TwinMOS winbond @ 5-2-2-2 @ 200fsb HDD Maxtor 60.0 GB 6L040L3 and Maxtor 80.0GB L01P080 CD-RW TDK veloCD 48x16x48x DVD Toshiba 16x/48X DVD VIDEO CARD 128mb ATI 9800 Pro @ stock speeds SOUND CARD SoundBlaster Audigy Gamer MONITOR Samsung 191T 19" Digital LCD SPEAKERS Logitech Z-560 KEYBOARD & MOUSE Logitech Cordless Freedom Optical ACCESSORIES 2xSATA and 2xATA133 cables
    WATERCOOLING SYSTEM COMPLETE
    WATERBLOCK#1 DangerDen MAZE3 w/ Lucite TopWATERBLOCK #2 DangerDen Z-chipsetPUMP Eheim 1250RADIATOR Black Ice Xtreme w/ 120mm Delta 130cfm FanRESERVOIR D-Tek Bay-ResFITTINGS 1/2" system with 1/2" Tygon R-3603 Tubing
    Hammerhead Shark jamesavery22's Avatar
    Northern VA, USA
    Yeah why is everyone saying they are going to be more expensive than buying your own pair of sticks? I know it makes business sense but hey Corsair might actually make a good deal out of this
    Mar 2001
    Cinci, OH
    Corsair and "Bargain" don't really go together so i doubt it :-P.
    Also, I don't think ANYONE will benefit from them "testing" to make sure the modules work "well" together. It will be no different than buying them seperately on your own IMO.
