SERIOUS WinXP Issue; Please Help!
Results 1 to 6 of 6
Thread: SERIOUS WinXP Issue; Please Help!
Threaded View
    Tiger Shark KommisMar's Avatar
    Oct 2002
    Hunting the Wumpus
    I've had some computer problems before, but nothing like this. This is so bad, and so random, that I haven't got a clue where to begin in troubleshooting it.
    I recently traded for a motherboard from a forum member, an ECS K7S5A Pro. To go with it, I purchased an Athlon XP 2400+ and a Seagate Barracuda ATA V 120GB. I partitioned the drive and formatted it NTFS, which I've not used before. Then, I installed WinXP Pro. All of the other parts in this machine were grandfathered from my previous computer. This is my first time not going with Intel, and so far it's been a real bummer.
    I have noticed three smaller issues with this machine, which may or may not be related:
    * I can't get a floppy drive to work with it. I've tried a couple of drives that I know work fine, and a couple of cables... nothing. But strangely, I couldn't get a floppy drive to work in my previous computer, either. The common bond between the two computers is the power supply... although that's awfully strange, and the power supply has exhibited no problems whatsoever (Enermax Whisper 350W, all rails seem fine).
    * Sometimes I can hit the power, and the fans and drives will start spinning, but the computer doesn't attempt to boot. No video signal, no beep from the speaker. I hit the power again, and it starts up. I did not have this problem with my old computer, using the same power supply.
    * I initially tried just swapping in the new motherboard and CPU and booting into Windows on my old installation, and I wasn't able to. I just got a black screen; no error. Couldn't boot into safe mode, either. But then, everybody knows you're supposed to install fresh when you get a new motherboard, so I didn't think much of it at the time.
    But here's the main thing:
    I began to get the system set up, and my programs and drivers installed, when after a reboot I got popup after popup saying "delayed write failiure". I kept rebooting the computer, but each time Windows would come up with a number of new warnings saying that important files couldn't be found. My file system was corrupting itself beyond belief.
    Microsoft's knowledge base recommends using a different IDE cable (but I've BEEN using the cable with no problems), or disabling write behind caching (which I tried, and I still got the error).
    I did find that I was able to boot the system into safe mode without any problem, leading me to believe that possibly the issue doesn't appear when your drives are in PIO mode.
    Check this out for more information about this error:
    http://www.hardwareanalysis.com/content/topic/2458
    Possible causes mentioned in this thread include the hard drive, ATI Radeons, and USB 2.0 enclosures.
    Well, the hard drive passed Seagate's diagnostic checker with no problem, and bad hardware is so uncommon that I'm not inclined to blame it.
    My motherboard has four onboard USB ports, and a few extra headers on the motherboard. I had two of the ports routed up to my Nexus front panel, and a third port is being used by my mouse. Interestingly, when I looked in the device manager, I saw that root hubs were listed by both VIA and SIS. That seemed a little strange to me, but maybe it's normal.
    I do have a Radeon 9000 Pro. It's never given me a problem, although ATI's driver support in WinXP seems a little spotty to me. One thing though, I think I may have installed the AGP drivers for my motherboard AFTER installing Catalyst 3.2. Seems strange that this would destroy my file system, but what do you all think?
    I'm at a loss for what steps I should take to troubleshoot this issue. I could try going back to my old motherboard and keeping the hard drive. I could try disabling more of the motherboard's onboard features. I could try installing my motherboard's drivers before anything else, this time. I could try formatting FAT32 instead of NTFS (but then, with no floppy, I dunno how I'd do that).
    If any of you can come up with some ideas here, I'd really appreciate it. I'm stumped.
    My Rig: A computer that runs Windows.
    My Page
