I have finally finished the Modding on the Sonata. It looks real sweet. Here's some PICS of the Steps.
1) Prepped and Ready for some Jigsaw Cutting!
2) The Jigsaw worked like a charm, I will be using this alot more for cutting then my Dremel.
3) Here we are with the filing mostly done, I will be fine adjusting with the jeweler files.
4) I missed a step but you can see I have added the Chrome Trim, and window.
5) You can see how I added the window with doubleside tape. (Tip, I doubled the tape so it be reach over the trim)
