View Poll Results: What OS should I use?
- Voters
- 35. You may not vote on this poll
Windows XP Pro
Windows ME
Windows 2000
Windows 98se
OS on a 233Mhz
i wannna see what os u guys think i should put on my 233mhz 128mb ram machine..i wont use it for gameing just serfing the net, using audio out and chatting
Windows 98 would probably be the best. But, support for 98 is not going to last forever. Windows 2000 will easily run on that machine, and for bare bones uses may be a better option.
If you really want 'em to be a single unit, duct tape your router to your modem. - Skydog 5/5/2005
MAIN - HP - e6300, 2GB DDR2, 300GB HDD, 250GB HDD, `6x DVD-RW, ATI X800GT, 500w Rosewill PSU
Work - eMachine T6520, A64 3400+, 1GB PC 3200, 300GB HDD, 16x DVD R/RW, CD-ROM, Via Envy Sound
HTPC - 2500XP, 1GB PC3200, 60GB HDD, 8x DVD R/RW, Via Envy Sound, ATI 9600PRO, 380w Antec PSU
SERVER - 1800XP, 512MB PC2100, 3x40GB HDD (RAID5), 2x40GB HDD (RAID1), DDS3 Tape Drive, 300w Enermax PSU
Windows 98,i ran it on my Packard Bell 233mhz
no contest. for those tasks with those specs, you should use linux. try libranet 2.7, which i think still uses IceWM as the default window manager, giving a very win98 feel (at twice the speed ).
workstation: athlon xp-m [email protected] | epox 8rda+ | 512mb | seagate 80gb+160gb | arch linux
web server: athlon xp 1600+ | epox 8k3a+ | 256mb | maxtor 30gb | debian linux
no way windows XP will run on that pc AND you want to use the net....after you dl SP1 on that computer or any updates...it'll run slow as hell....would reccommend 2000 cuz its stable....but i dont knw if you would want to dl the SP's on it......
....or you could go linux since you aren't doing anything that NEEDS windows...
Primary Rig
Dell Latitude D820 || Intel Core Duo T2300E @ 1.66ghz || 1024mb PC5400 Ram || Nvidia Quadro NVS m110 256mb (Geforce Go 7300) || 80 GB 5400 RPM HD || DVD-RW Combo Drive || 15.4" WXGA Screen
Secondary Rig
AMD Athlon 64 3300+ @ 2.64 Ghz || 768 mb PC3200 DDR Ram || Biostar Nforce 4 Socket 754 || ATI Radeon X850 Pro 256mb @ 580 core/1200 mem|| Western Digital 160 GB 7200 HD || 48x DVD-RW
The days of saying that Internet surfing works on a slow computer are over. This is the age of Spyware. The common man or woman surfing the Internet needs a 6GHz PC with 20GB of RAM to make sure they don't suffer from any spyware-related slowdowns. Too bad today's hardware isn't powerful enough to do it.
Core 2 Duo E6600 @ 400x8 1.37v
Zalman CNPS9500
ASUS P5k Deluxe WiFi-AP
4x1GB Buffalo Firestix PC2-6400 @ 4-4-3-11 800mHz (3327MB shows up in Windows)
500GB Seagate 7200.10
eVGA 8800GTS 640MB (A3 stepping) @ 700/1080
700W OCZ GameXStream
Antec P182 (sooo quiet with all fans at low)
22" Dell E228WFP Widescreen LCD
Windows Vista Ultimate 32-bit
3dMark06 Score with above OC: 11321
it is if you use linux, because linux doesn't have any spyware.
The Medieval Mod
Linux is not a bad option. Dowload a browser and a chat program and your ready
"Est Solarus Oth Mithas"
My Honor is My Life
(\__/)
(='.'=)This is Bunny. Copy and paste bunny into your
(")_(")signature to help him gain world domination
I run FreeBSD 5.1 on an HP machine that is similar.
I wouldn't bother with Win98se as it is very old and obsolete. Some web site will require IE 6 as a minimum very soon.
ok i am going to try to use xp just for kicks and giggles. i set windows for the "adjust for the best performance" if it is too slow i will work my way down to 2000 then 98se i heard ME is just a toy.
y not something like FreeBSD instead of 98se?
Primary Rig
Secondary Rig
well because i dont wanna take the to teach my family how to use a different os incase they wanna use it plus i dont really know how do use anything other than windows because i never tried. i used redhat b-4 but it was confusing...i just got xp on it and its running fine so far it hasnt been slow at all but well see what happens when i start installing programs
nuclear launch detected
anything less than 128mb ram will be nightmare on a winxp system. It will run with slightly less, but the swap file usage is like every 2 seconds... I already tried... win98 = the crapola... Anything slower than a 500mhz, i would reccomend win2k but on a 200mhz linux is probably your best bet
bitfenix prodigy, i5 4670k, asrock z87e-itx, zotac gtx 970, crucial m500 msata, seasonic x650, dell st2220t
Sleeps with the Fishes
A very stripped down version of win2k would probably be your best bet in terms of security, performance, and stability.
